current P#'s
current P#'s
this may be a repost but here it is anyway. im in the works of ordering a new piston lift pump and i got some current part numbers for all of the goodies. Lift pump-4988751 $192.20, spacer-3914284$13.25, gasket X2-3939258 $2.19, fuel line- 3914753 $36.82, seal x2-3963983 $1.28. these are the current #'s and prices as of today a grand total of $249.21
I was looking for the lift pump and found the part # was 4988747......Never mind this number is for a P-Pump on a 94-98 2nd gen. You can't use this piston pump without a regulator or you will blow out the seals on your VE pump.
Last edited by thrashingcows; 06-14-2010 at 02:44 PM. Reason: too much info...not enough knowledge....;)
If you go and see your friendly local New Holland, CASE or IH dealer, chances are they will have the same LP for less. There is a number swap, I believe the first 4 becomes a 3.
just want to note, I just ordered the above part numbers in the OP for my truck to do this job.
all part numbers were the same !
LP has gone up though, $260!
total $355.
total $355.
MNISB
10-23-2003 04:26 AM
