Cruise Control Switches
I am sure I can dig some up...
nothingbutdarts (10-19-2022)
it's not an ideal fix, but you can use 3 aftermarket switches to make the cruise work as well. 1 on/off, 1 NO momentary, and 1 NC momentary. here is how it would be wired with radio shack part numbers
black - ground
blue/red - 12v power when "on"(275-1565 ON/OFF switch wired through the brake switch as a safety)
green/red - 275-1548 momentary switch (set/decelerate)
tan/red - 275-1556 momentary switch (accelerate)
black - ground
The following 2 users liked this post by j.fonder:
rlyons (04-16-2016),
thrashingcows (04-16-2016)
What's cruise control?
If the plastic is in good shape, and you haven't tried to disassemble it and lost the little springs and pins inside, I have the repair switches themselves in stock, and the tools to replace them.
rlyons (04-16-2016)
that's how i'm going to have to wire the 1st gen cruise module to work in my '03 1500 cummins swap.
Same issue, 93 D250
hi if you still have these and the tools, can you please let me know how to reach you and place an order? Thx
Thanks
You can use a Dorman 525-104 with slight modifications to replace the OEM clock spring. There was a resent write up about it here.
Dale_K
10-25-2007 07:13 PM
vavtx
03-04-2006 10:22 PM
