Crewcab update...
Old 02-04-2020, 02:40 PM
  #1426
Received 1,334 Likes on 864 Posts
Originally Posted by NJTman
4bt in snowball?
Nope full 1st gen running gear. The 89 Motor that was in Patches when I bought it, and then a 518, and a set of 354 geared axles.
Old 02-07-2020, 04:36 AM
  #1427
KRB
KRB's Avatar
Originally Posted by Blue Goose
you're lucky...some guys end up being a daddy when their rubber breaks.....
Now that was a good one!
Old 02-27-2020, 04:32 PM
  #1428
Pulled the axle shafts last night since Pass side had no end play in the hub bearings and was running 5-10*deg hotter then the other side, not sure how that happened after my last brake/hub/seal service but it did. So reset both sides and crawled under neath looking for culprits for my driveline noise/vibration, well it to be Fair amount of play in one cup on the axle U-joint, little bit on the U-joint at the transfercase and the carrier bearing appears to be going south as well. I greased everything up for now but guess 6 years and 115K km's it's time for driveline servicing.
Old 02-27-2020, 06:41 PM
  #1429
Blue Goose's Avatar
yeah it does, but at least you'll be nice and toasty in the new shop when the time comes
thrashingcows (02-27-2020)
Old 04-07-2020, 04:18 PM
  #1430
Been putting off a bunch of work to poor old Patches, been concentrating pretty hard on getting the shop finished. But the carrier bearing has been getting worse and worse and the other day it made a horrible growling sound when I was driving so figured I better suck it up and bring the truck into the shop for some needed maintenance.
I pulled the drive shafts and then decided since I was under the truck I would do a couple other things as well, pinion seal and new biscuits on the tranny mount. Once the drive shaft was out of the way I did the pinion seal, only been leaking for close to a year now. First time I have done one myself, not too bad of a job but having a big impact would have made it a 15 minute job as opposed to an hour+ struggle.
These are the tools I used for the Re/Re...my grandfather old HD 3/4" drive Socket and wrench set, cheater bar and a pipe wrench.
Wedged the pipe wrench around the yolk and against the floor and then heated up the nut with the torch then big ratchet and socket and cheater bar to wrestled it free, once the nut was off it was a pretty simple swap.
Blue Goose (04-07-2020)
Old 04-07-2020, 04:22 PM
  #1431
Next was the tranny mount biscuits, I used the Anchor 2667 and 2668 parts.
Forgot to take pics of this but just loosen the nut and bolt holding it tight, then jack up the tranny/TC to give enough clearance to slip the old ones out and slide the new ones in. Once everything it lined up lower the tranny/TC back down and tighten everything back up.
Old 04-07-2020, 04:28 PM
  #1432
Blue Goose's Avatar
The following 3 users liked this post by Blue Goose:
edwinsmith (04-07-2020), nothingbutdarts (04-09-2020), StealthDiesel (12-20-2020)
  #1433
Now the big job of the evening, carrier bearing and 3 u-joints.
Pulling the carrier bearing apart for removal...
Just used a thin 1/8" cutting wheel on my angle grinder and a couple cold chisels to get it off. Outer shell removed....bearing has seen better days!
The inner bearing shell I just cut about half way through then use a wide cold chisel in the cut and give it a whack and it cracks and is able to slide off.
All the ugly pieces...
Old 04-07-2020, 04:37 PM
  #1434
Since I don't have a press I had to come up with a way to install the new carrier bearing, did some digging through my piles of misc stuff and found a piece of pipe/collar for something I picked up in a parking lot, and some 2" black PVC/ABS pipe, then a piece of 2x4 and my 2.5lb brass hammer.
Action shot...Well not really but close enough.
The following 2 users liked this post by thrashingcows:
Blue Goose (04-07-2020), nothingbutdarts (04-09-2020)
Old 04-07-2020, 04:41 PM
  #1435
Then it was installing the U-joints, again forgot to take pics of the process but sure most have done them before so use your favorite method for removal and installation.
New Spicer U-joints...
This was the worst U-joint, it was at the diff...
Now Patches is driving nice and smooth again with no more leaking on my nice gravel driveway...
The following 3 users liked this post by thrashingcows:
Blue Goose (04-08-2020), edwinsmith (04-07-2020), oliver foster (04-07-2020)
Old 04-07-2020, 04:46 PM
  #1436
Hahaha...I like that one but the last one should be..."You can't be stuck if you're a liquid!"
Old 04-08-2020, 05:04 AM
  #1437
KRB
KRB's Avatar
You've been busy! That all in your new shop?
Old 04-08-2020, 11:24 AM
  #1438
Shelby/Dakota's Avatar
cool to see that the rear pinion is as straight forward as it looks. Thinking mine is due though I guess ill also grab a carrier bearing and u-joints since I'll have it down that far. Maybe next winter lol.
Old 04-08-2020, 03:54 PM
  #1439
Yup first big job in the new shop....So nice to have a warm, dry and well lit work space.
Old 12-20-2020, 02:03 AM
  #1440
Wow have not updated in a few months....
Back in July I had to replace the tail pipe...was leaking really bad and looked like Swiss cheese.
Then in and around August I went through two water pumps, both were used units that had been on the shelf for a bunch of years, in fact I had not installed a new water pump since I bought my crewcab over 10 years ago. First one lasted only a few days before it started leaking, then the next one lasted about a month or so before it started leaking, so I finally bought a NEW water pump and everything has been golden since then.
Here you can see the one I had taken off first. I did not know that it was leaking because it had to weep hole, so the only time it would leak was when it was running. The next used one had the weep hole.
And now with a brand spanking new water pump.
Blue Goose (12-20-2020)
Quick Reply: Crewcab update...
