Crewcab update...
Old 12-17-2013, 04:33 PM
  #406
mknittle's Avatar
So that is the Non-gated set-up. I can see now why my Advanced Adapter bracket doesn't fit perfectly on my gated shifter....it's designed for the non-gated set-up.
Looks like I might have to do some modifications to make everything work....Main Story of this build it seems....
If it were easy everybody would be doing it.
Old 12-17-2013, 04:50 PM
  #407
Received 1,647 Likes on 1,120 Posts
Yeah if only a few of them actually lined up with the 4wd cross member and frame brackets...but I think I actually only ended up using 4 existing holes....and 2 of those had to be modified. Rest I had to drill.
Luckily the frames are relatively soft to drill. I had to drill out the front sector of my rig for the plow frame push bracket. I just used a step bit until I needed the final size and then used the correct bit for finalizing the hole.
Drill doctor sharpener came in real handy...
Old 12-17-2013, 05:17 PM
  #408
Received 1,334 Likes on 864 Posts
Yup I've fallen in love with the Titanium coated step drills!! Don't know why I have never used them before now.
Old 12-18-2013, 08:37 AM
  #409
mknittle's Avatar
They are the only thing to use on sheet metal that drills a round hole.
Maybe You resisted using them is they look like somebody's cheap gimmick
Old 12-18-2013, 08:45 AM
  #410
mknittle's Avatar
Smile
I sharpen mine by hand. LOL That reminds me I need to shorten a 3/8" and a1/2" to drill inside the top frame flange with the angle drill.
Old 12-18-2013, 10:34 AM
  #411
gyman98's Avatar
You can buy stubby drill bits, greenlee makes them for sure. I've got a set for using with a right angle drill.
I'm also a big fan of step drill bits they are just awesome!
Old 12-18-2013, 10:56 AM
  #412
mknittle's Avatar
I know I spent 20 years in machine work.
I can cut and sharpen broken drills to much shorter than "standard" stub drills. I have a 3/8" that I did that has less than one twist in the flutes. I cant buy that. LOL
The best part is it don't cost anything as I use broken and chipped bits.
And it only takes a few minutes.
Thanks for the info though.
Old 12-18-2013, 11:33 AM
  #413
mknittle's Avatar
OOPS I lied it is a little bigger than 3/8" it's 11/64" tap drill for a 3/8" hilicoil Here it is next to a standard 1/4" stub drill. if the shank needed to be shortened it could be really short. there is a definite advantage to this
Old 12-18-2013, 12:19 PM
  #414
Wish I had the knowledge to sharped my drill bits by hand. I use a crappy plastic and stone sharpener from Princess Auto (Canadian Harbour Frieght.. ). Works OK.
Old 12-18-2013, 01:20 PM
  #415
mknittle's Avatar
It really isn't that hard. the main thing is to have a fine grinding wheel on a bench grinder. and dress the wheel to make sure there are no groves.
the rest is practice. Look close at a nice sharp bit, hold it straight up tip on top. The cutting edge is slightly higher than the outside of where it is ground for clearance.
Attached Thumbnails Crewcab update...-110814_4lo.jpg   Crewcab update...-3659231_f260.jpg
Old 12-18-2013, 05:43 PM
  #416
CE_TX's Avatar
Looking really great thrashingcows!
Old 12-20-2013, 12:31 AM
  #417
Yesterday I got the oil pan gasket, and rear main seal done. Nothing really special about it...other then the 36 frackin bolts for the oil pan!!!
I wanted to get that done before I dropped the motor back in the truck. So today I did just that....motors back in. I also got all the clutch and bell housing assemblies installed as well.
Hope to have the tranny in tomorrow, and get the tranny mount located so I can drill all the holes in the frame for it.
Old 12-20-2013, 12:40 AM
  #418
And I'm seriously cheesed off as well. I've been searching for days for the transfer case shifter, boot and ring. Can't find it anywhere. I still have a few weeks before I'll be close to needing it...so hope it shows up before then.
Old 12-20-2013, 03:44 AM
  #419
KRB
KRB's Avatar
You roll that hoist & engine up and down that hill???
Amazing that you're doing the rebuild right there in the driveway and it's so clean! No oil spills/leaks, fragments laying around.
You covering the engine bay now I assume?
Looking good!
Old 12-20-2013, 07:42 AM
  #420
Received 2,536 Likes on 1,677 Posts
Thrashing.
Advanced Adapters makes a different bracket for the '92-'93 Z gated shifter.
I used that Z bracket adapter on my crew cab NV-4500 swap last month.
Quick Reply: Crewcab update...
