Crewcab update...
#346
I used the stock carrier bearing cross member and had a shaft built to my spec's with the big joint's and for the rearend I swapped a d70 yoke onto my 60 and I'm goin to do the same for the front because the gasser useing the smaller joint .
#348
I want to say the tube is 4 in ID all I did was take the end pieces into a shaft shop and have him build me 1 it wasn't cheap either 640 out the door for the 2 section rear shaft .but it had new joint's all the way plus new Carrier bearing .Brian On the crewcab's the carrier bearing mount's on a plate onto of cross member if you need that plate let me know .
#349
Yeah I have a couple pf the plates that the carrier bearing mounts on to. My crewcab, when it was a 2wd gasser...had the carrier bearing on a p-late on the cross member that span the bottom of the frame. Just a bit ahead of the upper one.
The upper one is the cross member that the cummins trucks use.
#350
Been working on the NV4500 4wd conversion the last couple days. Got the counter shaft in and end play set to .002".
Then it was start assembling the new fully splined 4wd mainshaft.
Start...
All done and ready to roll into the case....
And the tranny starting to look like a real functioning unit....
Start...
#351
Picked up my new front bearing retainer today. Not a bad piece...but it did require a little grinding on the oiling passage.
Not sure if you can see it in the pic, but the casting was almost level where it ran across the oiling hole. Once the bearing race was installed I doubt much oil would have gotten through.
A minute or so with the die grinder and a stone had things opened up....
Make sure you guys check these things when buying "new" parts....
So tomorrow I should have the tranny pretty much all back together....Wohoooo!
#352
Getting closer, my friend
#353
I'll post up a link to the other thread I started about the issue I found with the new 4wd mainshaft....
https://www.dieseltruckresource.com/...=1#post3214098
#354
Almost got the tranny finished tonight...
........then I noticed that the shift rail rod for 5th gear is worn badly... So now I have to wait on one last part before I can finally finish the tranny. Little cheesed off I never noticed the wear on that part before now.
Oh well I have a million other things I can work on in the mean time.
#355
So since I'm waiting for my shift rod to arrive ...I've been working on some other things.
Yesterday I got the front swaybar installed. Had to drill the holes on the underside of the frame to mount the bushing. Thank goodness I had bought a short 90* air drill some time back.
And I straightened the spot welded pinch seam on the tranny tunnel. Previous owner(s) cut and bent it to all heck. So I straightened it, and then trimmed off the excess...and there was a lot!!
And I started to make up the over plates to reinforce the cowl crack areas...
#360
Power Stroke IC
Then I thought I may as well get started working on my PowerStroke IC install.
I used the old front bracket for the Dodge IC I had removed before. I cleaned them up and trimmed them down just a hair on the one side. Then moved them all the way out on either side.
I then spent the next 2 hours trying to find the original bushings that mount on the bottom of the OEM IC and go into these brackets...never did find them.
So I used the upper bushing from the PS IC and trimmed them down to fit.
