Cowl induction hoods
Old 12-18-2013 | 03:55 PM
  #31
mknittle's Avatar
Why are there cowl vents at the base of the wind shield ? if the air passes that far above them when you turn the "vent on no air would flow through it.
Old 12-18-2013 | 03:56 PM
  #32
mknittle's Avatar
I cant get the smiley thingys to work.
Old 12-18-2013 | 06:34 PM
  #33
Twitchy's Avatar
When the air hits the windshield, a portion of the air flows down towards the cowl.
Old 12-19-2013 | 09:04 AM
  #34
mknittle's Avatar
exactly hence the cowl induction.
Old 12-19-2013 | 09:39 AM
  #35
peddlebike's Avatar
Cowl induction and a hood scoop are different things. Cowl induction works ...... it draws from that reversal/neutral air at the bottom of the windshield.
That 'Ram Air/Induction' system that is 3" from the level of the hood ...... looks/sounds nice. Does it work? Ask any racer ....
Old 12-19-2013 | 09:56 AM
  #36
peddlebike's Avatar
mknittle ....... dyno your truck, go home and cut the hole in your hood, add a hood scoop (remember: 3 scoops are better than 1), return for another dyno run ........ and let us all know about your hp/tq gains. I'll sell you an un-molested hood if the looks/dyno runs don't turn out the way that you thought they would ........
Don't forget to set-up the fans at the dyno ...... to simulate the ultra high speed that you'll achieve on the strip ......
Old 12-19-2013 | 11:09 AM
  #37
mknittle's Avatar
Actually I am going the other way. I am planning on using a bird bath hood on mine. Maybe the lower hood will be more aerodynamic.
Old 12-19-2013 | 05:23 PM
  #38
peddlebike's Avatar
Mark ...... you did find the 'smiley faces' ...... fun aren't they!
Old 12-20-2013 | 09:13 AM
  #39
mknittle's Avatar
I like them And have used them in the past. But for some unknown reason they quit working a couple weeks ago. I figured out a way around the problem but It takes a couple extra steps.
Montana2x2
09-28-2008 07:22 PM
stackx2
06-24-2008 08:08 PM
058hamer
04-10-2008 10:30 AM
SolarYellow05
09-10-2006 02:33 PM
cumminsho2500
09-08-2003 12:17 PM
Quick Reply: Cowl induction hoods
