It could happen to you!
I have been getting the truck ready for pulling my jeep this season and noticed something real edit! My wife had been driving it for a few days and I noticed a puddle under it yesterday, I thought it was the AC drain, it was not. I have manual gauges in the truck, and where the temp. and oil lines enter the cab the temp. rubbed a hole in the oil line, putting about six quarts of Delo in my carpet. Luckily I found it in time however, I also discovered a whole new world of rust I had to cut out the carpet from this area, and now save my $$ for a restoration. I usually use this site for info, thought I would contribute this, something that is easily overlooked!
Just to prevent such occurences, I slip a length of flexible-tubing over any fluid-lines where they enter the fire-wall, or any other place of possible damage.
Also, always install a shut-off valve at the source of pressure, then plumb the gauge-line to that; then, if something does go wrong, the valve can be closed and simply eliminate the gauge from the system, to be repaired at a more convenient location.
Now that is the way it should be done.
quadman20
25
07-06-2007 06:56 PM
Dodgezilla
15
12-24-2004 08:22 PM
