View Poll Results: Which water/meth system do you suggest/prefer
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Coolingmist/Devilsown/Snow/Other
Trying to deccide which system to go with so figured I would poll to see what people are running. Please vote then add a little as to why you support that system.
I can not comment on any other water/meth kit but I am sure happy with my snow mpg max picked up four mpgs on a recent trip 22.1 was my best and I got 26.2. As for cooling ability I am 50-75 degrees cooler at cruise have not towed enough to really say there but I did notice less smoke and the smoke I saw was more of a gray haze than black. Easy to install. Instructions were easy to understand etc.
alwaysonDTR
at least i would think so.
mosty i think you will get the i have this kit and it works great,
if you compare the same gpm nozzles and pump psi/gpm in each company then the only thing one company could have better than the other is the controller, but i used a boost switch with a manual override
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_173.jpg
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_176.jpg
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_177.jpg
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_179.jpg
150psi pump, 2 .380 nozzles in the grid delete spacer. Works really well for me with stock injectors. Gives a little kick under hard acceleration when it starts spraying at 16psi and keeps EGT in check towing with a 12cm exhaust housing.
http://www.coolingmist.com/detailmai...d=VC2dieselegt
This is the kit I am really looking into. I will be using this as a daily driver and tow rig on the weekends to haul the boat and other toys.
I've only had experience with the older Snows and it's variable controller, it's a very good controller, never had any trouble with any part, and I bet the new ones are even better. The Snow's kit a a whole is a nice setup in my opinion.
I like that 250psi pump - should work exceedingly well. Use a bigger tank for sure. I expanded my tank to include a 2nd 2 gallon tank for a total of three and would consider that bare minimum.
They are running a special on them right now and if you buy the whole kit you can upgrade to the 7 gallon tank for $25.00 more. So I will deffinately go with the 7 gallon that way I wont have to refill as often.
I'm running the coolingmist stage 3 with the smart controller, I see they now offer a stage 3 without it. So far it works well, I got it when it first came out. There was a bit of wiring to do for the install, but there customer service was excellent though so it made the install a little easier.
I was really wanting the Labonte motorsports variable injection system but they didn't offer it for a mechanical injection engine.
Red3quarter
12-12-2009 11:12 PM
Rpainter
01-26-2008 12:27 AM
wildmanben
12-02-2006 12:40 PM
