Conversion has begun, Have Questions
Old 09-06-2006 | 08:39 AM
naw_t's Avatar
more pics
Got some more progress pics on the above link. Body is resting on the frame and now I will start with the bosy mounts.
Old 09-06-2006 | 07:44 PM
csramsey640's Avatar
I have to say it looks pretty sweet Those wheel wells look just perfect on that frame. Keep us informed.
Old 09-07-2006 | 08:07 PM
naw_t's Avatar
Update/questions
More pics on the original post......
Can somebody I.D. the the tranny for me. I think it is a NV4500. Just want confirmation.
I have the body more lined up, need to adjust the radiator, hook up clutch, Alternator(any input here ford vs dodge),order Borgeson shaft for steering, and finish up body mounts. Not bad for a week worth of work.
Any sugestions/inputs are welcomed.
I am still not sure if I will put the dually tires on or run some 35's.(If I do then the wife wants 35's on her powerwagon )
Thanks for all the support.
NAW_T
Old 09-08-2006 | 07:11 AM
JD730's Avatar
Doesn't look like a Getrag, most likely someone swapped the whole shooting match in there NV4500 and all when they did the engine swap.
Old 09-08-2006 | 07:32 AM
jughead's Avatar
fordge
i did the swap a few years ago in a 71 ford. on the master cylinder i used the ford and the dodge slave. i used the dodge plastic line, heated it in oil till it was soft and it slid over the ford master cylinder fitting. has worked fine for several years. be SURE TO CLEAN all the oil from the plastic line
Old 09-08-2006 | 07:34 PM
That's an NV4500.
Old 09-08-2006 | 11:02 PM
BearKiller's Avatar
The easy way to connect the Dodge clutch cylinder to the Ford master is to push out the little roll pins that hold the lines in the masters.
They will then be a direct swap; simply push the pin back in once the line is swapped.
Old 11-21-2006 | 06:01 PM
Would like to know what problems you ran into bolting up the body, if any. Not sure if you still come on here or not. I know a 77 is a different frame, just wondered if the same could be done with a 80-86 or 87-91 body truck, only visa-versa. Dodge body on ford frame.
Thanks
roughstock
05-02-2008 11:26 AM
95black2615
15
08-19-2007 09:17 AM
CumminsRedneck
04-26-2007 07:47 AM
signature600
33
02-07-2007 01:30 AM
