Connect Electronic Speedometer to NP203 Transfer Case?
Old 10-08-2004 | 12:39 PM
PeteRR's Avatar
I've got the stock '93 electronic speedometer from the donor truck and I need to hook it to my NP203 TC that requires a mechanical cable. Should I just replace the speedometer with an aftermarket mechanical one or is there an adaptor to tie the two together? Anybody else run into this problem?
Old 10-08-2004 | 04:29 PM
Alec's Avatar
You should be able to use an adapter from a 93 (or so) truck . . . the NP205 transfer case has an old fashioned mechanical gear, with a gear-box and sensor screwed into it. I have no idea what ratio adapter you will need, BUT frostie bought a box somewhere that will multiply and divide electrical pulses, so you could get any adapter an make it work that way . . . Frostie runs his speedo off the ABS ring in the rear axle.
TrxR
04-19-2007 03:57 PM
csramsey640
Off Road / 4x4
09-08-2006 06:34 AM
MedicShawn
03-29-2005 01:51 PM
justdirt
10-06-2004 02:32 PM
Quick Reply: Connect Electronic Speedometer to NP203 Transfer Case?
