compression
Old 06-29-2010 | 06:14 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
Originally Posted by KD93
And that should answer your question, boostedve. Unless JBradley500 is wrong. I wouldn't know!
lol i probably am.
Old 06-29-2010 | 12:00 PM
jimbo486's Avatar
standard compression ratio in these beasts is 17.5:1. as it's been said, much lower will make for harder starts, inefficient burning of fuel. if you watch all the pulllers with low compression ratio and tons of timing, they're blowing white smoke idling until they bring RPMs up. white smoke = unburnt fuel due to low combustion temperatures. think about how close the piston comes to the surface of the head with a stock gasket, the air gets compressed A LOT and in turn, heats up A LOT. if you put, for example, a .020" gasket it may increase the volume of the cylinder, thus, the potential for a higher volume of air to fill it. but, the piston doesn't come as close to the surface of the head as it did before, leaving some of the air (probably not much) partially compressed and only partially heated for complete, efficient combustion of the fuel. make some sort of sense? i could very well be wrong, but that's how i see it. as for streetability, i'd rather keep my 1/2RPM starts with a stock compression ratio. but, if you're looking to pull or race, the low compression ratio and advanced timing is the way to go.
Old 06-29-2010 | 07:03 PM
boostedve's Avatar
thanks jimbo
Old 07-15-2010 | 06:55 PM
soggy's Avatar
My new engine is going to be about 15-1, hope it works out ok for street driving.
I am looking for a DD so I can just use this as a toy tho..
Old 07-15-2010 | 07:40 PM
JustRamIt91's Avatar
y not high compression?? i've read somewhere that higher compression is ideal for better terminal efficiency something like 70% is achievable..
Old 07-15-2010 | 07:53 PM
JQmile's Avatar
I would just use a .020 over gasket and leave it at whatever compression ratio that is. FYI my truck hazes now with big injectors and a .020 h/g.
Old 07-15-2010 | 07:56 PM
jimbo486's Avatar
that'd be quite a task!
shorter rods, cut the deck height, possibly a new crank with a different rod journal throw and even a new design of the piston bowl or piston altogether. not worth it if you ask me.
Old 07-15-2010 | 08:05 PM
if you want lower compression and r going with a larger headgasket y not port/polish the head and blend the valves seats into the combustion area? I'm sure there is volume to be had in the head....
Old 07-15-2010 | 09:35 PM
soggy's Avatar
I'm planning on making big power with it some day, you know with a edit-pump Plus I'm hoping to get a new DD soon.
Old 07-16-2010 | 09:59 PM
RuralCruiser007's Avatar
I know with Chevy and their 6.5 are 22-1 ratio. You get over 15 psi boost and things are not good. I have a boat anchor sitting at home because of this.
The differences with running a 20 thousands thicker head gasket is not that much. When you start playing with lower compression ratio pistons, then the fun begins.
Old 07-16-2010 | 10:03 PM
didn't know the 6.5 had so much compression... no wonder why they "knock" like kids on Halloween. A low compression diesel....just doesn't sound right to me. I'm open to new(to me) ideas though
Old 07-17-2010 | 01:21 AM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
According to my ROUGH math, stock combustion chamber is around 56 ccs and adding .020 over adds 4ccs to that. After doing some late night math that comes out to around .1 compression change. Again, very rough math. Using over all bore volume and known compression ratio of 17.5 to 1 I estimated combustion chamber to be 56 cc's and a .020 x bore area = 4cc's then back track numbers with updated chamber size gives 17.398. But its late and I hate math. Not sure how low you can go before its hard to start, but lower compression would give you more volume to play with in the chamber for a given volume of pressurized air. 7% more volume of combustion chamber volume. Not sure how much that affects cylinder pressures though. I am curious how hard it is to get some of these puller trucks running. Hope this helps a bit.
Aaron
Old 07-17-2010 | 09:02 AM
dzl_damon's Avatar
So did the 185hp 7.3L IDI and the 125hp Mercedes 3.0L OM617.
High compression ratios, low boost (even though the MB can handle 30psi or so), and inferior indirect injection.
Old 07-17-2010 | 11:25 AM
The high compression is needed to compensate for the inefficiency of the IDI combustion system. IDI does have some advantages, for instance it is much more tolerant of variances in fuel quality.
Commatoze
09-30-2004 12:53 PM
kingofdodge7131
11-24-2003 12:16 PM
geof
11-16-2003 07:20 AM
SjLingenfelter
06-30-2003 01:35 PM
Quick Reply: compression
