Command start with manual?
Remote start correct?
I don't see why it couldn't be done but leaving it in neutral is going to be a key factor. god for bid you leave it gear that one time It'll crank over and start and possibly drive away.
I went up over a curb one time with just the power of the starter and in 1st gear
That's what I meant, Mr. Smarty Pants.
My truck will start in gear with the clutch out. Scary thought. I just had driveline work done on my truck and I taped a huge sign to the steering wheel letting them know that not only would it start in gear, but it'd pretty much take off immediately upon turning the key.
Mine was MIA when I got the truck I learned the hard way one day my grandfather n I where trying to diagnose a problem he goes to my truck reaches in n hits the starter with it in gear. First of all how stupid is it for someone to do that? second he's a licensed heavy duty mechanic and mercedes mechanic lol.
Anyway sounds like a bad idea to me.
My old first gen had one in it with a five speed when I bought it, some sort of sketchy looking box with a cable to the shifter to make sure it was in neutral, the remote start never worked when I got it and never tried to make it work, as a mechanic who installed remote starters I refuse to put one in any vehicle with a standard, too much that could go wrong, I'm not comfortable doing it!
My truck did not have one on it when I got it either. I park inside our warehouse at work and almost put my truck through a wall when I went to start it after a 16 hour day. Something I did not even think to check, could have mad a long day even worse.
hey-Hey!!!,
I have a manual with a defeated clutch switch. I made a habit of wiggling the shifter back and forth between the gates( left-right, across neutral ) every time before I stick in the key. Key not in before I've made sure it is out of gear. Makes a double take when I get in to drive an automatic ov course, but that I can live with( and it doesn't happen so often anyway ).
cheers,
Douglas
cheers,
Douglas
BTW I tested the system and found that even in 3rd gear with the park break set, the starter could overcome it all and the truck could drive away on its own. I did this in a safe area while I was behind the wheel......
Now days you can have them installed with a couple of micro switches on the shift lever and a special arming sequence pretty reliably but it never seemed worth the hassle to me. Besides, If it's cold enough for me to start the truck to warm it up before driving away, I like to set the hand throttle to give it a few more RPMs.....
hey-Hey!!!,
IMO, unless you've got the resources to create a neutral safety arrangement, a remote start with a manual is a *BAD* idea. I'll add *RELIABLE* neutral safety arrangement. The auto companies have not taken this lightly, and IMO it is a bit beyond most ov us.
cheers,
Douglas
cheers,
Douglas
JJK98CTD
02-07-2009 12:23 PM
