cold weather/grids
Old 12-12-2008 | 11:29 AM
93beater's Avatar
Question cold weather/grids
when its cold out my truck will never get up to normal summer driving temp with the temp guage standing straight up?? why is this wouldnt it warm up enough after about 30 mins... another thing is how do i remove my grids...if there restrictive im down to toss 'em... its not too cold down here or any where i go... will it add boost? power? is it good/bad for your truck?
Old 12-12-2008 | 12:41 PM
Tuckerdee's Avatar
If your engine isn't getting up to operating temp. then I would suspect your thermostat is bad. Normal temp is not with needle straight up and down. It should hold to about the second line on the gauge. At the base of the "normal zone." If your needle is straight up and down all the time, during summer operation, then I would expect your radiator isn't working as good as it should. Where does your needle stand during winter operation?
Old 12-12-2008 | 02:24 PM
93beater's Avatar
the normal temp for down here is the needle straight up and down... there a a couple first gens around here and thats exactly where they all run... they cant all be bad. and it will eventually get to normal temp but it takes about an hour, when its like 20* outside... the thermostat is good im positive..... thats whats confusing me??
Old 12-12-2008 | 07:24 PM
Several companies sell "grid delete" spacers. The truck will do just fine without them.
However, you will not pick up a noticeable amount of power. Leave 'em be, spend your money elsewhere if you are looking for power.
Old 12-12-2008 | 07:26 PM
The thermostat IS bad if it takes the truck an hour to warm up. What leads you to believe the thermostat is working properly?
Old 12-12-2008 | 11:04 PM
ofcmarc's Avatar
You don't get cold enough in Texas foryour truck not to warm up after a half hour evern runnin' empty. At -20* runnin' empty I can get to 180*F after 10 minutes on the highway. I would definatley look into a t-stat problem.
TIMMY22
12-21-2010 02:53 PM
joel
01-22-2005 08:59 PM
Mule Skinner
01-08-2005 09:22 AM
KATOOM
01-05-2005 09:40 PM
wings
11-08-2004 05:32 PM
Quick Reply: cold weather/grids
