Coil Spring Project
Old 08-01-2007, 09:50 PM
TJE
TJE's Avatar
Coil Spring Project
I'm going to be attempting to install the coil springs on my truck, and I have a couple of ?'s
1. Do you have to compress the spring in any way when installing it?
2. Is there anything else that should be changed while I'm doing the springs?
Thanks, Tony
Old 08-01-2007, 10:45 PM
PapeCAT's Avatar
no compression, just stick em in there and use a jack on the LCA to get them compressed and into place.
Old 08-02-2007, 11:27 AM
gomerpile's Avatar
is it the same way for the super heavy duty MOOG lift springs?
Old 08-02-2007, 02:47 PM
12valve@heart's Avatar
Only thing that I've found is that you may need to chain down the frame or lifting the lower control arm to compress the spring may lift the entire truck. I chained the frame to the floor jack before I started jacking so that the frame couldn't raise up.
Old 08-02-2007, 07:25 PM
TJE
TJE's Avatar
I hope this isn't needed because I have nothing to chain it too!
Gomerpile: My springs are the severe duty from napa. I just want to do this one time. Later, Tony
Old 08-02-2007, 08:44 PM
mhuppertz's Avatar
I didn't realize any 1st gen trucks had coil springs (except on the valves). I haven't ever been around a 4x2 I guess!
Old 08-03-2007, 09:33 AM
C Pierce's Avatar
I put in super HD Moogs and did'nt need to use a chain just slowly dropped the jack.
Old 08-03-2007, 01:34 PM
That's why I had to chain from the truck frame to the jack frame. I didn't have anything else to chain to either. Good luck with it.
Old 08-03-2007, 08:04 PM
TJE
TJE's Avatar
Thanks for the help guys. I was going to try to put them on tomorrow, but the truck is in the shop having the a/c worked on. So maybe on Monday. Later, Tony
Old 08-04-2007, 08:43 PM
apprentice's Avatar
go rent the spring tool just for safty sake....i am all for hi ballin and get er done...but springs can and do kill
Old 08-07-2007, 10:32 PM
TJE
TJE's Avatar
Update
Well I finally got the truck back from the a/c guy, so I started on the springs.
I went by one of the write ups here on the forum, got the driver side in. Maybe tomorrow I can finish. Later, Tony
Old 08-10-2007, 09:01 PM
TJE
TJE's Avatar
Finally
Holy smokes does the truck set up now! It raised the front end so much I might need to raise the rear some. I forgot to measure before I started but it is at least 2 to 3 inches from where it was. Took it for a test run and not really that bad, not as bad as I thought it would be. Later, Tony
Old 08-11-2007, 10:43 AM
Let it settle for a few months before you jack the back up.
Old 08-11-2007, 12:16 PM
TJE
TJE's Avatar
Yeah that's my thoughts. I figure it will come down some. It sure looks good right now. Later, Tony
Old 08-11-2007, 01:43 PM
chumstone's Avatar
how much did the new springs cost?
Quick Reply: Coil Spring Project
