Clutch problem, advice please...
93 4x4 with light fueling and air mods. On the rag... other day in 5th I laid the pedal down and she took off and suddenly slipped the clutch a little, never happened before. Everything felt done after that until I was at work yesterday a little aggravated and threw it in reverse and took off a little aggressively. Now the clutch doesn't engage until the pedal is near top of its travel, literally right when my foot comes off it... what's going on here? The master is full, slave showers to be functioning correctly. Could my clutch have taken a crap that quickly? Thanks in advance for any help you can offer!
-Jesse
-Jesse
Generally when the clutch starts to go you get a slipping when you push the throttle down and really notice when pulling a grade with a load. It should grab when the pedal is coming off at the bottom. Sounds as though you might be needing a replacement soon.
You might have smeared a side or part of a side clean off the disc. If that is the case, it is doing a number on the pressure plate. ...Mark
Depending on what you want to do with your truck, tow heavy, tow light, race, ect. They have designs that will work on all kinds of apps. Installing yourself or having a shop do it. I have a South Bend clutch which works great for me others have used different brands. The websites of the manufactures have all the details of what the different applications can do.
Mt. Dew
21
06-29-2010 09:35 PM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
