Chopping turbo???
Chopping turbo???
I have a 93 1 ton 4X4. And when I am making the boost climb, It sounds like it is chopping the air, it also makes this sound when I'm under boost and just lift off the throttle rapidly. I was wondering if anyone can help me figure out why it does it?
Thanks
Thanks
It real shouldn't bark(the chopping you here) under a load? I can see you putting a good load on the eng(causing the turbo to spin up) and then releasing the go peddle abruptly to get that noise................What is different then stock on it?
Do you have a boost and pyro gauge on it?
Flash
I have an exhaust brake on it, but it barked before that was installed also,
4" straight pipe to 5" stacks,
16cc turbine housing,
pyro and boost gauges
4" intake with K&N air filter with a filter wrap
I also built my 12V bottom end with a 24V top end.
275 Hp nozzles.
aneroid cranked up
I pull 28 psi boost during just normal driving
Building my twin turbo set up for some more power
Methanol injection is on it's way.
275 Hp nozzles.
aneroid cranked up
It's a slot cut in the inner ring of the compressor housing right by the tips of the compressor. It lets the excess air just circulate instead of backing up and then blowing back through the compressor.
now that i installed the i/c housing on mine from 15 to 25 psi it makes a sound like small flutter but my boost gauge doesn't bounce and the bearings are brand new, what could it be is it surge?
