Changin shift forks
Old 01-03-2011 | 09:01 AM
12valvin's Avatar
Changin shift forks
How hard is it to change a shift fork in the getrag? Called the local tranny shop and they said it was better to just get a reman top cover.
What do yall think?
Old 01-03-2011 | 09:14 AM
CaptainChrysler's Avatar
You can change them out fairly easily. You have to remove the plugs in the end of the shifter cover. There are some roll pins to remove too, and the detent ball will fly out if your not careful. It is possible that there are several worn pieces in the shifter cover. You may want to check everything over for play and/or slop. A worn out shifter cover can make the trans shift like crap.
Old 01-03-2011 | 09:24 AM
12valvin's Avatar
Ya im pretty sure its just the shift forks but does anybody know where to get a remaned top cover for under 350? The only place I have found is drivetrain.com
Old 01-03-2011 | 10:18 AM
You might check Bluementhal sp? or Zumbrota bearing.
Old 01-03-2011 | 05:00 PM
Exekiel69's Avatar
I had one of this fly and hit Me right in the eyeball, damm|t that hurt.
There is also a piece (can't remember what is called) with a spring inside it that the shifter will push and select which fork to move, this can wear too so You want to look at this and see if it need replacing. When You are done ordering parts for shifter cover You might as well get a new one, when I called the shop I get the parts from they had parts but all used, although they do sell new shifter covers.
Old 01-04-2011 | 10:35 AM
12valvin's Avatar
Ok so I just ordered my shift forks from Zbag, is there anything else I need?
Old 01-04-2011 | 05:58 PM
GIT-R-DONE's Avatar
A 6 pack of your favorite beverage and alot of patience
Old 01-06-2011 | 03:26 PM
12valvin's Avatar
Are yall reusing the plugs in the end of the cover?
Old 01-06-2011 | 03:39 PM
I did. Put lock-tite on them.
boeingguy
08-04-2015 07:09 PM
mknittle
10-23-2014 01:49 PM
staarma
12-03-2010 03:51 PM
03dodgeoffroad1
02-24-2009 08:20 PM
thumbs
03-01-2003 06:21 PM
Quick Reply: Changin shift forks
