Changed CPS, still no alt chrg/o.d ??
Old 02-19-2010 | 05:15 PM
DNRCustoms's Avatar
Well, did the kdp on project dually today and put everything back togatehr with a new CPS from cummins and Im still not charging or over drive. I also had the alt tested and it is working fine. So, I'm thinking maybe swapping a computer to try that. maybe you guys can throw some ideas out that I'm over looking.
Old 02-19-2010 | 06:11 PM
What's the gap and did you try tightening it up a few thou?
And you're sure the wiring harness isn't chafed?
At that point, try another PCM if you have it. Also check continuity between the sensor plug and the PCM plug to make sure the wires are OK.
Old 02-19-2010 | 07:58 PM
DNRCustoms's Avatar
Well, I set the gap at a nice tight .050.
I went thru all the spots where it would wear, it all looked good. Man I was sure hoping the cps would take care of it. I hate guessing with money when it comes to electrical components. Good thing there is only a few sensors on the old girl.
Old 02-20-2010 | 11:39 AM
DNRCustoms's Avatar
Well, swapped in a computer off another truck and the alt is charging great!! Looks like I need to find a good used one now. Im sure they aren't available and huge$$$..
Old 02-20-2010 | 12:29 PM
jesussaves's Avatar
i had the same problems and it was the computer. I bought mine off ebay (new) it has a lifetime warranty but it sure is expensive
Old 02-20-2010 | 01:54 PM
AutoZone can get you a reman.
Old 02-21-2010 | 12:11 PM
dodgenstein's Avatar
You can also add an external regulator off of a 70's Mopar or there are instructions on one of the diesel forums about adding an internal regulator to the ND alternator on your truck.
Mopar_Aaron
01-24-2014 01:48 AM
jesussaves
07-18-2009 05:45 PM
Ryathis
09-14-2006 04:42 PM
John In NC
10-22-2005 09:14 AM
Quick Reply: Changed CPS, still no alt chrg/o.d ??
