Cb antenna mounting ideas
i really wanna get my cb gpin but am having a hard time deciding where to put the stinkin antennas.
What have you guys sone and how does it work? Ps i am havin duals no matter what lol
You picked a favorite subject of mine. First, do want dual anrtennae to look cool, or do you want your CB to really work well. Dual whips require a minimum of 108" between them for then to work properly. Put a tape measure on your truck. 108".
All that you need for any mobile CB (unless you have a 1000 watt linear amp) is a Wilson Little Wil, it is a small magnetic mount CB antenna, tune it so that your SWR is lowest on channel 20 and your all set.
If you really must have dual whips, mount them on your mirrors and only hook up the wire to only one antenna, it will work better.
One of my favorite laughs is when I see trucks with the duals mounted to the bedsides, behind the cab, worst placement ever for a mobile CB antenna.
If you are not a perfectionist pr1ck like me, who expects everything to work to it's full potential, then just put your dual whips wherever you want, just not behind the cab as it destroys the signal pattern.
I have always had the best success in mounting them on the mirrors.
It gets them about as far apart as possible and also gets the loaded thingie above the roof-line.
Well mine are mounted in the bed rails on either side behind the cab. You learn something new everyday as I didn't know that was a bad location well it looks cool anyway lol.
I have a cobra radio with tunable wilson sticks. I thought that as long as you could get the radio to calibrate you were good. I am new to cb's so someone educate me.
Those Wilson whips are very good antennae. To get the best tune, use a single cable and tune each one by itself, then connect both antennae. Find an open area, no trees, no power lines, doors closed when you test.
The optimal position for the antenna is dead center, or offset about a foot towards the rear of the cab roof, single mast, as far apart as you can get them for dual whips.
When you put them behind the cab, it creates a 3 level ground plane, 2 horizontal and one vertical, which causes all kinds of havok with your signal output. Some one receiving your transmission will hear more distorsion and your range is cut down quite a bit and will be stronger in the forward direction, like a long oval instead of a nice, equal circular pattern.
I am not sure what the swr reading is exactly but the needle barely moves at all that is the reading that I am going for right? The tip of the antenna is not below the roofline they are 4 foot antennas ant they are mounted to the bed rails.
Those Wilsons tune real easy. The signal radiates from the whole antenna shaft, not just the tip, that is why behind the cab makes it screwy. It sounds like you have it tuned as well as can be expected, besides the built in SWR function/meters are not known for stellar accuracy, just functionality. But they are good enough to keep you from burning the finals out of the transmitter due to a badly mis matched antenna.
If you just bought a radio from a retail place, have it peaked and tuned by a local CB shop, that will help improve your signal range with the cab blocking some of the signal. A CB is like a VE pump, there is some power to be gained just by making some adjustments.
I had a piece of steel that I bent into a 90* angle, apinted it and then bolted it to the bed. Its in the middle and top of the bed. I then have a Wilson magnetic, that has about a 4' whip on it, mounted on it.
I think the Wilson has one of the better antena out there, JMO. It is currently not installed as I had the radio "turned" up not long ago and ahvent reinstalled it yet. Too many other irons in the fire. Tune in the radio / antena with a swr meter and your set.
The set was peaked and tuned at the shop I bought it from. I talked about 6 miles the other day is that a pretty good range. I also have a 225 watt linear if I need it I will install it.
I want looks and performance lol i like how they look on the mirrors, just not how sloppy the wires look runnin into the windows. Any ideas for that one??? Lol. And thanks mr extreme!
