camshaft
Old 02-26-2010 | 10:33 PM
stackx2's Avatar
camshaft
I have a non I/C engine that has a couple of pistons melted out of it. my question is if i replace my intercooled cam with a non I/C will i get a performance upgrade with the mods that i have done. just kickin the idea around a little.
Old 02-27-2010 | 01:43 AM
soggy's Avatar
Not 100% sure but I think the non I/C cam is slightly better. You would be way better off just getting a Diesel Pros drop in tho.
Old 02-27-2010 | 02:02 AM
dstad's Avatar
Im pretty sure to deal with egt issues without a i/c on the early 12v's they installed cams with longer and larger durrations to help move more air which = cooler egt's. SO yes i do believe youll notice a slight diff.
Old 02-27-2010 | 08:18 AM
93 12v's Avatar
Would the valve clearances be the same though? I mean, with bigger cam lobes would he be running a risk of hitting pistons at high RPM's without better springs? Just a question.....
drawson
05-04-2004 12:03 AM
hustler
03-31-2004 08:07 AM
al*gray
03-18-2004 07:57 PM
thumper 549
07-27-2003 08:34 PM
1ST GEN.
11-07-2002 10:39 PM
Quick Reply: camshaft
