buying a turbo
buying a turbo
im thinking about buying a d-tec 64-71-12 to go with the 6-16 injecter im getting will that combo work well in a pulling truck or should i go bigger on the turbo any input will be appreciated
what is ed 63/68 and i thought i would be ok with the big turbo becouse of the 5 speed but it kind of sounds like thats not the case and i mite be wasting alot of money on a big one
I thought it'd be the opposite. With a stick, you're going to loose boost when you change gears, so it'll take longer to build boost back up again with a big turbo.
alwaysonDTR
I'm running a 60/65/12 and it spools right away, but with the small housing when i pull hard or sled pull it runs 40psi and chokes at high rpm. i'd like the 14cm housing for daily driving, bet it'd work well for sled pulling.
97C-PowerPuller
07-19-2012 11:36 AM
diezel nutz
05-19-2009 04:30 PM
heykw
04-11-2008 04:59 PM
Ahousaht Diesel
05-24-2007 07:41 AM
