Broken injection pump mounting stud
Hey all, first post here.
I pulled a pretty rookie move last weekend, on the tenth timing adjustment of the day, I broke one of the studs holding the IP on. It was the top one closest to the head, and it broke pretty flush with the back of the timing case. I've driven around a little since then with no issues, but any ideas on how likely it is that it will stay that way? And if I do need to fix it, would it be easiest to go from the front of the timing case or take out the IP?
Thanks,
J
Thanks,
J
Thanks,
J
Thanks,
J
Edwin
nonrev (04-28-2020)
Well I fixed the KDP ages ago, I was mostly worried getting metal shavings in the crankcase if I end up having to drill it out. I guess I did have a boss one time that would say "that's what the oil filter's for"...
You can drill it out and just before it goes through put a glob of grease on the end of the drill bit, and it also wouldn't hurt to magnetize the drill bit if you have a strong magnet around.
You can stuff a rag into the opening to drill the stud then use an easy out.
Edwin
