Broke the Record! 854rwhp from a VE!!
#46
November 5th will be the day to see who comes out on top! When I was stationed in Jacksonville, FL years ago I had a 2000 chevy dyno 323whp with just a aftermarket muffler. So the true test will be both top trucks on the same dyno the same day. Thatll eliminate variables.
Both trucks are well built, and its amazing to see a small 62mm turbo able to make 850whp with nitrous. A turbo that small is good for a daily driver as well as being able to tow. So I wouldnt call Jasons truck a dyno queen. Even though he couldnt beat my 5 speed down the 1/4. Hahaha.
Who ever wins Nov 5th, good luck to both of you! Yall have lit a fire under me and I plan to catch up very soon.
#47
#48
#49
I ran my 6x.016s with the stock h1c for awhile before I built twins. About the same difference as running the 5x.025s with the 62/65/14. Towing with it would be a smokey, pyro pegging PITA.
#50
Question for all of you who have trucks that are performance ish built how much money has been dumped into your trucks I am looking for a rough ball park figure cause the truck in my sig is sitting in my front yard and unless I can come up with something cool or smart to do with it I am putting er up for sale not to get off topic but I would love to know guys and november fifth should prove to be a monumental day for not just Jason and Stomp but for the rest of us 1st gen owners
#51
#52
Okay thats a way better figure than a guy I know told me he said he has about 40 grand into his and it will run 10 something the 1/4 and that it will do 270 kilometers on the hi-way lol
#53
$40,000 is very easy to hit in a truck you want to run 10's, especialy if you pay shops to do the work.
#55
I thought so too, but I might actually try it. On the way back, I was able to climb a 5% grade at 3,000 feet with no smoke, and only 900 deg on the pyro. Granted I was in 3rd gear with the converter locked, but I still think I could probably tow as long as I kept the rpms up and speed down.
#56
on this current tear down and build I'm at about $8k under the hood. Still need a larger set of injectors, and then I can work on the trucks appearance. I figure by the time I put $15k into it, the truck will be perfect. May sound like alot, but it will be 1/3 the cost of a new diesel, run much faster, and get better mpg. not that that really matters.
#57
I really believe a guy can build 350 hp for 3-5k, and i'm talkin trans to, and 450 hp for 7k.
were not tolkin a dyno, or drag, or pullin truck, but a good dependable usuable towable truck like Snoot, Ahineman, and some others have.
Dar
Dar
#58
#60
What is the magic number 1/4 mile wise for a getrag first gen to be in the mag?
