Bought a first gen!
Old 03-05-2014 | 06:52 PM
w250 guy's Avatar
By internal hub you mean inboard so to change the rotor the whole hub and bearings and all that good stuff has to come out aswell?
Old 03-05-2014 | 08:32 PM
Originally Posted by w250 guy
Only things really wrong with it now is the frame got quite a bit of surface rust but is still solid as a rock! And there's some rust starting above two of the wheel wells and the gutter above the windshield is pretty rust, not really sure how I'm gonna fix that yet...
When you attack the frame, drop the fuel tank down and clean out behind it. These truck are notorious for frames rotting out behind the tank, as dirt, leaves, mice and other junk gets in there, and traps moisture.
Here's my KDP with pix. Not difficult if you have some tools, and can turn a wrench in the direction that makes screws come out, or go in....
https://www.dieseltruckresource.com/...2-t305946.html
Old 03-06-2014 | 09:08 AM
m-o-p-a-r's Avatar
No, either way, to change rotors, you have to go through all that fun stuff.
See how all you see of your lock-out hubs is the shiny chrome cover (and 6 small allen-head cap-screws)? Those are "internal hubs".
External hubs would be black. have a big ole' **** you turn for engagement, and be held on by 6 9/16" head bolts.
Your truck would have come with external hubs.
Old 03-06-2014 | 09:32 AM
mknittle's Avatar
Originally Posted by m-o-p-a-r
Pretty sure that is not the original front axle. It has internal hubs, which I don't think came from the factory until the 1991.5 models. Consider it a bonus.
Sweet looking truck!
My 90 donor has the internal hubs. My dads 89 has the externals though.
Old 03-06-2014 | 09:43 AM
mknittle's Avatar
Are you old enough to remember the old "lever lock" hubs? Those were even more fun than the selector **** style.
m-o-p-a-r's Avatar
Really? I could very well be wrong! But, I was under the impression that the internal hubs came about at the same time as the intercooler and overdrive automatic, in 1991.5'.
But, now that you say that, I had a 1990 gas engine W350 a long time ago that had an internal hubbed dana60 under the front of it.
But, the donor for my Cummins ramcharger was a 1990, and had external hubs.
Hmmmm?
Old 03-06-2014 | 10:02 AM
m-o-p-a-r's Avatar
Ohh yea! "dualmatics", weren't those fun!
Old 03-06-2014 | 10:28 AM
maybe368's Avatar
Hmmmm?
My 90 has the internal type on the D-60...Mark
Old 03-06-2014 | 10:34 AM
mknittle's Avatar
Hmmmm?
It seems like every time I think I have these trucks figured out somebody has one that is different. I have come to the conclusion that that the first gens (maybe all) are a mixed bag.
Old 03-06-2014 | 10:36 AM
mknittle's Avatar
Thanks I couldn't remember the name.
Old 03-19-2014 | 05:24 PM
w250 guy's Avatar
Can any of you help me figure out what the paint codes are for this truck I cant seem to find anything on it anywhere?
Old 03-20-2014 | 10:40 AM
james1's Avatar
Killer d pin? im not sure what that is...
In Post #14 of this old thread:
https://www.dieseltruckresource.com/...d.php?t=307483
I attached the Technical Service Bulletin issued by Cummins detailing how to repair the KDP. Our First Gen trucks have the "bossed housing."
I suppose this defect was considered "non-safety related," as neither Cummins nor Dodge saw fit to issue a recall.
At this point you're on your own if the pin falls into the timing gears and ruins your engine.
rascal
08-23-2011 08:22 PM
mviverit
01-11-2009 05:56 AM
MunK
04-13-2008 11:35 PM
97CTD
07-29-2007 09:22 AM
MikeThomas
02-12-2007 06:51 PM
