Bottom radiator hose trans cooler fitting size
Guys i was wondering if you can take off the nipple that ran to the trans cooler that used to be mounted on the pass side of the motor? It is located on the block where the coolant return goes to from the heater core tubing. There used to be a trans cooler cylindrical deal hooked up to it that i trashed. the nipple im talking about is the one that runs horizontal not vertical and only came on automatics. Does anyone know what size this nipple is and if you can remove it? thanks guys
Wow this is the first thread that i have ever posted that no one knows about. just trying to get some info maybe i haven't explained it well enough someone chime in.....
Relax, a little more patience wouldn't hurt.
That fitting is for 5/8 water hose and should be either 3/8 or 1/2 tapered pipe thread, not completely sure which because I've never had to remove that one.
no no im not trying to be impatient its just usually its lickety splitt on these things. i just wanted to make sure you guys weren't sleeping. jk jk So it is removeable then?
On another thought like the name my grandpa has always told me about the 2 cylinder john deeres. Are the pistons as big as a 5 gallon bucket?? thanks
but then again it is kinda an emergency because there is coolant leaking all over the place so impatience might contribute a little bit. however thanks for your replies
RHC
03-04-2011 08:22 PM
DodgeRamdiese01
10-24-2009 04:54 PM
