boost pressures
Old 01-23-2008 | 01:44 AM
Ilikebikes's Avatar
Originally Posted by DodgerDoob
When I swapped my original turbo with a 16cm housing to the HX35 with 12wg, my boost dropped from about 26 to 22. I still can't figure that one out.
I'd be willing to bet that your wastegate is opening at 22PSI.
Old 01-23-2008 | 10:00 AM
ol' 93 12 valve's Avatar
Im at 6-10 psi at 70 600* at WOT 38psi 1000*-1100*
Old 01-23-2008 | 10:54 AM
CaptainChrysler's Avatar
I finally got a WG hooked up, now have 36psi, can hit 1000* post turbo empty. It is about 10* outside though. I didn't adjust the WG. I am pretty sure it is opening at about 18-20 psi. Need to drill out the divider. Running 60mph, I see about 5 psi and 650*.
If you put on a stock housing it will open at about 18-20psi.
Old 01-24-2008 | 02:48 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
5 - 10 psi at 60 and 750-850 WOT 43 psi egts going through the roof
Old 01-24-2008 | 07:07 AM
boostedve's Avatar
5-8psi at 60mph and about 500-600 WOT 46-48PSI EGT ABOUT 1200-1300
AT ABOUT 3800RPM...
Old 01-24-2008 | 06:08 PM
powerrammaster's Avatar
Ive got a Banks 14w/g and before I disconnected the boost on the wg , I could only get 10 with it to the wood, now I can punch it up to 20 briefly. Cruising I'm showing 4-5 at 600* and up a long grade about 15psi/1000* with ambient winter temps,empty.
O.T
09-18-2007 01:50 PM
DMAN99
07-12-2007 10:12 PM
toupee
06-27-2007 05:19 PM
Earthmover627
09-03-2006 11:08 PM
thumbs
08-03-2003 10:06 PM
