boost pressures
Old 08-08-2007 | 12:13 AM
Garrett5462's Avatar
boost pressures
i just got my boost and exhaust temp gauges put in and i was wondering what types of pressure it should be reading. i have the stage 4 compressor kit from HTT and the 16 cm housing.
when im just driving, the boost doesn't really go up at all, and when i floor it, it will go up to about 18 psi and thats the most it will go.
and for the egt, when the truck is idling, it reads about 200-250 degres and about 400-600 when im just driving. when im on a hill or im just giving it alot of gas, the temp will climb up to about 850-950. But even climbing up a long steep grade it never got above 1000*.
just wondering if these readings are normal. thanks
Old 08-08-2007 | 12:25 AM
Sounds like you need to turn the pump up some more.
Old 08-08-2007 | 12:45 AM
bloodhound51's Avatar
more steam captain
Old 08-08-2007 | 03:25 AM
MikeThomas's Avatar
Im running the same hardware, but when I punch it--bam--32psi. Time for you to break out a 13mm wrench and a screwdriver son. Hey bloodhound, does your hula woman make things go faster? I use mine as a tachometer, when her hips start-a-shakin I know its time to shift
Old 08-08-2007 | 03:32 AM
yeah buddy couldn't make any hp at all with out that hula woman only thing is shes a smoker. hahahaha
Old 08-08-2007 | 09:12 AM
JD730's Avatar
Ha, thats probably the funniest thing I'll hear/read/see all day.
Old 08-08-2007 | 02:31 PM
Gman_dodge's Avatar
Ya im usually around 10 to 15 with normal driving then up to around 30 when im really on it. my egts are over 1000 when getting on it usually
Old 08-08-2007 | 02:37 PM
Boatnik's Avatar
I,m running around 700 to 800 cruising with minimal boost. WOT 35 to 37 pounds and lots of heat. "We gotta slow down Captain. She canna stand the strain".
Old 08-08-2007 | 02:45 PM
mhuppertz's Avatar
Mine bogs, then slams up to 35 psi where is will apparently stay until I ventilate a piston!
Old 08-08-2007 | 04:44 PM
maxx250's Avatar
I was gonna ask that same question as I just go my boost hooked up,Im reading about 5-10 driving around and 20-25 when accelerating.About 600 on the egt cruising
Old 08-09-2007 | 09:08 AM
kiszka6911's Avatar
I would say about 35 PSI (gage is pegged) with about 1000-1100 EGT.
Old 09-18-2007 | 11:23 PM
Gman_dodge's Avatar
that sounds about right....with my superchip i can really feel her pulling when the turbo kicks in. hoping to get injectors soon!
Old 09-19-2007 | 12:59 PM
DodgerDoob's Avatar
When I swapped my original turbo with a 16cm housing to the HX35 with 12wg, my boost dropped from about 26 to 22. I still can't figure that one out.
Old 01-22-2008 | 11:46 PM
feveree40's Avatar
I'm getting 34 psi out of the stock turbo at about 1000* on long hills. 8-10psi and 750* cruising at 65.
Old 01-23-2008 | 12:28 AM
Free89W350's Avatar
At WOT I see around 36 psi and the EGT's are ..... lets just say not good, I can hold it to the boards for about 30 seconds before the 1600* pyro is pegged . Now with the valet on crusing at 65 on the highway I see 10-15 psi and 600* on the pyro. I need more air I'm trying to push to much fuel through the stock turbo.
