Bomb suggestions
Old 03-06-2005 | 07:12 PM
G1625S's Avatar
Bomb suggestions
Well, my buddy and his wife are moving back to this area from Nashville, TN. in about two months. I jumped at the chance to help out, but now I need some BOMB advice. I'll most likely be pulling an 8x10 enclosed cargo trailer pretty well loaded up with household stuff as well as a harley in the bed. I don't see the trailer breaking 5500 pounds and the harley is a sporty, so maybe 550 or so. I know this isn't monster weight, but I am intercooler challenged, so temps could easily be an issue. Would it be better to turn down the fuel, or just watch the right foot? Here's a list of mods I wanted to do sometime by the end of summer---lemmie know what I should look at doing before the trip:
1--BHAF
2--rips 4'' exhaust (got mandrel bent 3'' to 3.5'' mandrel bent tail pipe now)
3A--water/meth w/just water towing to cool things off
3b--intercooler, also to cool things off (duh )
4--rear air bags...she's squattin about an inch in the back. I'm thinkin about compensating with the bags since I run empty 90 percent of the time.
5--my turbo is stock and tired...I'd like a piers hybrid, but $$$ may limit me to a less tired h1c for now---she's not scrapin yet, but I don't think I'll be safe making the journey with my present turbo. Maybe just a 16cm...
6--governor spring---in the tool box waiting for this week!
7--any added suggestions or comments on the above are greatly appreciated. I'd like to get the best towing bang for the buck to the tune of about $1000 over the next 60 days.
Thanks, as always.
greg
Old 03-06-2005 | 07:32 PM
Well, at $1000 you're pretty limited. A good used WH1C or HX-35, the governor spring, water/meth, and the air bags will pretty much kill the budget. You gotta run some meth in the system to keep algae from growing in the tank.
Old 03-06-2005 | 07:38 PM
G1625S's Avatar
Well, I've got the spring (all 16 dollars worth ). I guess I'm wondering if I should struggle with the I/C retrofit (I've seen a few floating on e-bay) or rely on water/meth. Ideally, I'd like both, eventually, but which would be more cost effective to start out? Thanks for the reply, Dave.
BTW, I am NOT looking forward to towing with the Detroit---that thing is downright spooky running empty
Old 03-06-2005 | 07:51 PM
Unless you get a smokin' deal on the parts the intercooler install will eat up around $800 - $1000. I believe water/meth is more effective, but it does have the drawback of being a constant small expense, basically like getting worse fuel economy. Water/meth is a much quicker install and the initial cost is lower.
The Detroit will calm down with more weight on it.
Old 03-06-2005 | 07:58 PM
G1625S's Avatar
Thanks again, Dave. Where can I shop for water/meth?
Old 03-06-2005 | 08:10 PM
There are two main companies making the systems, mine is from Snow Performance.
http://snowperformance.net/default.asp
I highly recommend the Snow setup because of the progressive controller. It makes the water/meth work so seamlessly, you can't really tell it's working until you turn it off.
I wouldn't bother with the Stage 1 kit, it's really more for low boost stuff like Powerstrokes and GM 6.5's. I had to raise the pump pressure a lot on the Stage II kit with both nozzles installed to be able to bog the motor, I'm sure a Stage 1 would have been maxed out and still not able to bog the motor. If you can't bog the motor, that means you could put more water/meth through and make more power and have a better cooling effect. They say at 50/50 the quantity injected only needs to be 25% of the fuel injected - I go through about a quart a minute at full boost and there's no way I'm burning a gallon of diesel a minute.
I can't recall the name of the other company off the top of my head, but I know Cethane is using their system.
Old 03-06-2005 | 08:11 PM
G1625S's Avatar
Cool! Thanks!
greg
4x4dually
06-05-2006 11:11 AM
DieselRaptor
11-14-2005 07:16 AM
flyfsh70
05-08-2005 11:33 PM
YinYaker
11-10-2003 01:28 PM
iwannaram
10-13-2002 02:10 PM
