body work $$$
body work $$$
Anyone give me a rough estimate of what it would cost to change out the right side rocker panel on a 92 ext. cab. One estimate was 1200 to change out both. I probably will have it done one at a time for financial reasons and the drivers side is not near as bad as the passenger side.
When I first got mine, I was quoted $1000 for both rockers and cab corners with rust protection. They way everything else has gone up, $1200 would probably be more accurate, but a little more work involved than what you stated.
I've got a body part book. says that a slip on is 21 bucks and a complete is 33 that is your cost not whole sale. Not sure if that is for the ex cab and regular.....i would assume that they are the same.
Mainer
Mainer
I would assume you will incure more costs doing them one at a time, especially if you need new cab corners. I was told the box has to come off or be pulled back in order to get at them properly. I would try to do them both at the same time, think about the quality time you will miss out on with the ole' girl....
Trooperthorn
01-07-2011 12:55 AM
cumminsdriver635
05-01-2004 10:41 AM
