Bleed RWAL HOW?
1st Generation Admin
- Bleed Master Cylinder.
- Bleed RWAL.
- Bleed right rear wheel cylinder.
- Bleed left rear wheel cylinder.
- Bleed right front caliper.
- Bleed left front caliper.
Hope this helps.
- Bleed RWAL.
Hope this helps.
Bleeding
When I did my brakes awhile back I installed speed bleeders in calipers, RWAL and rear cylinders. The cost far outways the hassel of having someone help you bleed the brakes. Buy some silicon tubing and make sure the end of the tube is in some brake fluid when bleeding.
I think the size is 3/8" for the calipers and cylinders and 5/16" for the RAWL. NAPA carries them or order off the internet.
Works for me
Jim
Works for me
Jim
Bad Ramer Jamer
13
01-12-2008 05:38 AM
