Blasted Power Screw
Old 01-19-2005 | 04:06 PM
fearthedeere's Avatar
Blasted Power Screw
I need to crank up the pump some more but i cant get to the screw. how do i get to it.
Old 01-19-2005 | 04:44 PM
ARedetzke's Avatar
I use a 1/4 inch drive SK wratchet with a deep well socket to break loose the locknut (think it is a 13mm). I have to put the socket over the power screw, and then hook the wratchet to it. Once that is broke loose, you can either use a small end wrench to turn the power screw, or a small flat head screw driver. If your timing is advanced and the pump is rotated up towards the block, adjusting the power screw gets more difficult. I used to be able to get to it a lot easier than I can now.
AJ
Old 01-19-2005 | 05:26 PM
jiMMyCTD's Avatar
i think i have pictures of everythign i used to turn fuel screw in and reset idle
EDIT, ill upload it tonight.
jiMMy
Old 01-19-2005 | 06:57 PM
its like frozen in there
Old 01-19-2005 | 07:07 PM
caleb c.'s Avatar
Hey buddy I know what you mean
Old 01-19-2005 | 07:38 PM
ive done stripped the shat out of it. im callin it a nite and startin a bon fire
i hate to love my truck
Old 01-19-2005 | 07:44 PM
ARedetzke's Avatar
Did you get the lock nut loose first???
Old 01-19-2005 | 08:13 PM
yep too that off my truck hates me
Old 01-19-2005 | 10:38 PM
Bushy's Avatar
Patron Saint of 1st gens
Just use a 1/4" drive ratchet with a 6mm socket on it...loosen the fuel screw back off a bit and that will "drag" the locknut with it. You can fiddle with the snugging up part later...in my case, I can loosen the screw, back the locknut up, say, 1/4 or 1/2 turn then turn the screw back in till the locknut starts to tighten up and then use the wrench to finish the job of tightening it.
bob..
Old 01-20-2005 | 04:06 PM
Im gonna solve the problem the redneck way and since i cant use duct tape on it ill just weld a nut on it and then crank it in.
Old 01-20-2005 | 11:44 PM
swank's Avatar
well, that certainly is the redneck way to do it. good luck. where's the pics of your stacks?
Old 01-21-2005 | 07:35 AM
ive had to buy the parts a lil at a time. between gettin raped at the pumps and tryin to gettin my hay equipment in shape for this spring, my money has been lackin as well as my time.
Old 01-21-2005 | 11:10 AM
swank's Avatar
what parts are you still needing?
Old 01-21-2005 | 03:29 PM
i still need to buy the 5in t spliter its like 90 dollars
Old 01-23-2005 | 12:42 AM
swank's Avatar
i'm guessing you've got a welder, so it would be pretty easy to put one together for the price of two 90's. i can send you a pick of the one i've got sittin on the bench if you want. after getting it, i realised how simple they are.
