Bigger Harmonic Balancer that fits 93
Old 01-29-2022, 02:40 PM
Federic's Avatar
I just want to thank you both...specially Oliver who took the time to explain way too much I'm sure but helped tremendously!
Thanks again and I owe you a beer if you ever are out this way in AZ funny thing is I was in Vermont delivering a bucket truck about 6 months ago
Old 01-29-2022, 03:53 PM
Received 2,539 Likes on 1,679 Posts
Been awhile since I was in AZ, picking up an old Dodge....I might not be able to take you up on that beer right off.
I am glad to help. Low buck upgrades, like 24V balancers or turbos on early non intercooled motors, are something I do enjoy.
Improving my ride with some leftover stuff around the shop.
Post back your results after the balancer install.
Federic (01-31-2022)
Old 01-31-2022, 11:58 AM
Federic's Avatar
finally got the fan off..left hand threads trying to find out if the balancer 4 bolts are also left or normal threads...you Know?
Got the balancer coming should be here by friday wil post pic of old one once I figure out which way to turn nuts to take off
Old 01-31-2022, 12:02 PM
Standard rotation bolts on the balancer.
Old 01-31-2022, 03:16 PM
Federic's Avatar
so thank you got it off and too kpics and videos of balancer...here they are it looks to me that it is a bit loop sided but your opinion is greatly appreciated!!
can see it is getting higher on one side here in pic
Old 01-31-2022, 04:40 PM
Received 1,334 Likes on 864 Posts
You remembered correctly Oliver....
Yes I have a fluidampr on my motor they don't officially offer it for 89-93 motors but I bought it anyway and figured I could make it work. Originally it was on my 89 motor and I had no issues, but when I went with a 93 motor I had issues with clearance between the fan blades and the balancer. I had to put shims between the clutch fan and fan hub to move the fan out 1/4" or so, I still get the odd contact from time to time mostly under hard acceleration or high RPM's.
Old 02-01-2022, 01:26 PM
ScubaSteveCA's Avatar
I went with the fluidampr kit when I did my head gasket and front seals. It's pricey but it came with a nice bracket for the CPS and it made the shut-off squeal go away. Best $500 I ever spent. I think I even splurged for the arp bolt kit. Done once, done right, never do it again. My stock balancer was actually missing like 1/3 of the rubber
Federic (02-01-2022)
Old 02-01-2022, 01:50 PM
Federic's Avatar
mine was off in some spots no rubber missing but the fact that the vibration starte under full on throttle towing 7000 up over 7200 feet makes me think it is that..specially after redoing the driveshaft and balancing tires...Mine was not a real big vibration more a rhythmic one...was your really big with that much rubber missing or not?
Old 02-01-2022, 02:43 PM
There was a lot going on. I replaced my engine mounts about 2 months prior to that as a power steering fluid leak from years prior had eaten the driver side to jelly. . I'm just glad it didn't come apart on me. When I priced the oem, it was about half the fluidampr price. Only downside is removing the cps to change the belt, its not a big deal, but its a thing.
The following 3 users liked this post by ScubaSteveCA:
Federic (02-01-2022), nothingbutdarts (02-02-2022), thrashingcows (02-01-2022)
Old 02-04-2022, 01:22 PM
Federic's Avatar
new one done
SO..finally got the new balancer and installed it...seems to be running much smoother and no vibrations but only took it 2 miles around here..Also pics for the difference in size and condition between the stock 160 and the 215 one the tach pick up still fits which is great..the belt is pretty tight against a couple of the nuts and pulleys BUT it doesn't seem to rub
Thanks again you guys!
Huge difference in size but runs smoother now it seems
The following 2 users liked this post by Federic:
nothingbutdarts (02-04-2022), peckens (02-04-2022)
wcurb
08-01-2018 09:06 AM
6 Shaker
09-10-2006 11:52 AM
VADSLRAM
09-11-2005 08:52 PM
slim51015
08-16-2005 02:24 PM
Quick Reply: Bigger Harmonic Balancer that fits 93
