Best gooseneck hitch?
I've used B&W turnover ball hitches on my previous 95 and 03 duallies. Is that my best choice for my 93? Does the ball socket hit the differential like it did on my 95 when fully loaded? Is there a better choice?
I haven't heard anything bad about B&W's. The only thing I see "wrong" with them is that when installed, they actually sit just in front of the axle rather than directly above it. This may not exactly be a problem with B&W but more so the holes in the frames of the trucks being too far forward. Just my opinion. I only know this to be an issue on 3rd gen trucks as I've seen the one in my grandfather's '03.
As for install on our trucks, their website states that drilling of the frame is required. That would allow one to center the hitch directly over the axle. One other thing I'm curious about on first gen trucks is the frame differences above the axle. Some have a slight rise/arch to them on the top rail and others are flat. So I'm told, anyway. Both of my trucks have a(n) rise/arch there. So I haven't seen a comparison.
That being said, I'm not sure how the hitch would do with that rise/arch in the frame.
You wouldn't be able to move the b+w any farther back then where it is intended to go without modifing the plate. My truck is lifted but the directions do state not to carry the ball upside down if you have a 2wd.
The holes are all drilled from up top. Pretty easy. I think cab and chassis have flat frames and would require a different hitch
What brand of bags are you guys using? I have to install a gooseneck in my 96 and they Air-lift kit said side mount hitches will not work as im guessing they move the top of the bag out???
I put a B&W turnover in my 92, the first time I put 2 tons of coal on it I found out I couldn't do that without the ball hitting. I made a plug for the hole and removed the ball when hauling heavy. Since then I installed Air-Lift bags and have no problems with whatever I put in the bed. I really like the hitch and the bags.
My apologies, I've never owned one just heard they did. I was thinking about the b & w and if the "L" notches were cut down it should be able to slide back some
You actually want the hitch a few inches in front of axle centerline, it puts a little load on the front of the truck. I have a Reese, Ive abused it for over a million miles. Had 5K on the ball, no problems. Its 2 rails with a plate that uses 4 pins to hold it in, pull the pins and remove the plate or if you want to use a 5th wheel, just set it on the rails and pin it in...
Also Jimbo the front edge of the B&W hitch is made with about a 1" 90* bend down to allow for the hump in frame, the rear of the hitch is flat and lays on top of the hump, you can't slide the hitch back or it won't be level. So I would assume they intend for the ball to actually be ahead of center of the rear.
05-14-2010 05:06 PM
