best combination for tow rig
Old 08-15-2009 | 02:57 PM
Featherman's Avatar
As the title states, what would be the best combination for a tow rig? Best injectors, turbo and other mods.
I'm not talking about towing 20,000 pounds just some moderate weight 7-10k.
Old 08-15-2009 | 04:40 PM
archer39's Avatar
auto or manual?
Old 08-15-2009 | 05:04 PM
Tranny--- (if auto like says in your sig)
Goerend $550 torque converter or something similar,
Bigger trans cooler (unless you have factory underbed cooler)
Deeper pan w/more fluid capacity
Trans temp gauge
Transgo HD shift kit
Engine---
370 Injectors, (5x12) ??
Super HX40 w/16cm housing ??
4" downpipe and exhaust
Upgrade intercooler tubes
BHAF air box w/filter
Advance the timing and rotate the stock fuel pin
Gauges of course (pre turbo EGT pyro and boost)
That thing would be a pulling tank,
Just throwin some stuff out there, if you upgrade your torque converter and keep the tranny cool you could probably tow pretty good with just a few pump tweaks and a stock engine.
Old 08-17-2009 | 01:54 PM
apwatson50's Avatar
What is the point of going bigger on the tubes, especially the hot one, where its just going to neck back down again? The elbow into the engine sure.
PS IC.
Old 08-17-2009 | 02:15 PM
dzl_damon's Avatar
I'm thinking you WOULDN'T want to turn the fuel pin for towing, so you aren't giving too much fuel and getting our EGT's too high in the hills at full boost. I guess It can always be rotated back in 5 minutes though.
Old 08-17-2009 | 02:32 PM
I don't think that tiny difference in the fuel pin would make a big difference in EGT's if you have enough turbo.
Thats what i meant apwatson
Old 08-17-2009 | 06:06 PM
Featherman's Avatar
Good debate guys which is what I'm looking for. I have an HX35, set of PODS and 3200 spring kit and I was wondering if I'm better off leaving those for the crew cab and finding another combination for the dually, which will be the main workshorse for any towing. Also have the gauges and a DTT rebuild kit.
The dually already has a rebuilt tranny but not sure what components are in there. I'm led to believe the internals were updated along with the flexplate.
Old 08-17-2009 | 06:07 PM
Yea the HX35 and PODS are gonna mix well with towing.
torque Converter is the main thing.
Old 08-17-2009 | 06:26 PM
archer39's Avatar
you just put PODS and towing in the same sentence
morkable
09-12-2006 09:56 AM
Math_Teacher
04-26-2004 05:22 PM
GIT-R-DONE
03-22-2004 03:35 PM
wv smoker
02-02-2004 05:59 PM
