Bastardization of 47RH
Just wondering if this is possible. Can I take a dodge 47RH with the 28 spline output shaft and swap in an output shaft from a jeep 727 with 23 splines??
It might take atransmission guru on here for your 100% certain answer, but I believe that since the 47 RH has a lock up torque convertor it has a different numper of splines and the end of the output shaft is different. I would want to have that verified before taking it as gospel though.
What exactly are you trying to do and are these transmissions 4 wheel drive or 2 wheel?
I was under the impression that 47 RHs were 28 spline but I could be wrong. What I am trying to do is mate a 4bt to a 47rh and then attach that to the 23 spline np229 in my wifes jeep grand wagoneer. If dodge made a 23 spline shaft thats is the same as jeeps that would make life ALOT simplier!
JD730-what year is your 23 spline 47rh?? is it 4x4? Thanks
My 47RH is out of a '95 truck, all 4x4 47RH's are 23 spline. It is a 4 wheel drive model.
I'm gathering the jeep has a 727 in it now. It should have a 6 bolt circular pattern. Don't take this as gospel, but your transfer case should bolt up to a 47RH.
Let me help to clarify. The 47RH output shaft is 23 spline, yet the output shaft length makes for a different TC input just for these 47RH trannies available in 94-95. The TC bolt pattern is a 6 bolt circle, too.
You'd need to measure the TC input shaft neck of both TC's, and also measure the TC mounting flange., they may be different. It may bolt up, but only one way to know for sure.
1 Post
remember a diesels "rpms" are much lower than a gasser. A gas transmission/transfer requires much more "rpms" to reach a certain speed.
when was the last time you reved your cummins up to 4500 rpm?
Are you just trying to swap the shaft into your existing tranny or your shaft into another tranny?
nate_o23,
Find yourself a diesel 47RH (47RH's should have only been for diesels and V10's, if you get a V10 47RH you need to change the governor in the OD section), bellhousing, flexplate and bolt that right to your 4BT and have some fun. Make sure your transfer case has an 6 bolt circular pattern.
Dangit, 8 bolts are wrong, I just found the pics of my transfer case, its 6 bolt. Must be thinking of something else.
OK, I am probebly wrong about the 28 splines (wouldnt be the 1st time I was wrong ) So just to make sure I have this right, the 47 RH output shaft is 23 spline with a 6 bolt patern?? Im not sure of the NP 229s bolt pattern but it is 23 spline so at least I have that going for me.
turbo6justin
06-22-2004 06:59 PM
BoldtsWagon
01-24-2003 11:05 PM
