backspacing for 15" rims?
Old 05-31-2005 | 04:26 PM
pmtg's Avatar
i have a set of tires (35x12.5 R15) with only ~2000 miles on them. i want to eventually be able to use these on my truck after some suspension modifications.
i remember some time ago (cant seem to find it with the search function) the maximum amount of backspacing to fit 15" rims on our 1st gens. i would want a 15x10 inch rim, so what amount of backspacing is required? is it possible or am i losing it? i dont mind the tires sticking out past the fender.
thanks for the help, Pat
Old 05-31-2005 | 07:22 PM
ChrisLib's Avatar
I don`t think 15`s will clear the brakes unless you do some major grinding on the calipers.
Old 05-31-2005 | 10:29 PM
timb's Avatar
Chris is right, your not going to put 15 " rims on a 3/4 ton truck unless you grind your calipers down to nothing. best to stick with 16" rims.
Old 05-31-2005 | 10:55 PM
DODGE 92's Avatar
i wouldnt recommend it especialy if you got 4500lbs front axle they will never fit best thing is to get rid of those tires i tryed it too too much work involved
Old 05-31-2005 | 11:12 PM
jiMMyCTD's Avatar
2.5 inch BS wheels fit
Old 06-02-2005 | 08:07 AM
pwrtripls1's Avatar
2.5" back spacing will leave 7.5" sticking out. Thats alot of wheel sticking out from the fenders.
Old 06-05-2005 | 05:10 PM
jiMMyCTD's Avatar
right. i was just saying that they fit without grinding the caliper down if he so choses. i run them on my cruiser's front 60.
Redneck-Express
05-01-2009 01:45 PM
PEAKSTRYDE
10-11-2007 05:20 PM
kawi600
02-28-2007 09:59 AM
Tiara3100
03-19-2006 12:12 PM
