Aux trans cooler switch/sender
I have the under bed mounted aux trans cooler that the previous owner cut the wires from the temp switch and replaced it with a straight wire. I'm assuming that he did this because the fan wasn't working - I've never seen or heard the fan come on, even at the top of a pass.
A few questions:
First of all, does the switch/sensor that's mounted in the cooler make the connection between the two attached wires, completing the fan circuit, or is one wire connected to ground, the other connected to a relay? Would jumping the swith/sensor make the fan stay on all the time?
Also, is there also a toggle or rocker switch that enables the aux cooler? I have and extra toggle switch that I'm not sure of the function. Where is the aux. fan relay located?
A few questions:
That cooler was a dealer installed option, my '93 FSM has no info on it.
That said, I'd imagine that jumping the switch will turn the fan on. It sounds like you need to spend some quality time with a 12v test light.
The cooler should be automaitc, but who knows what a PO might have done. Perhaps the thermo switch failed, or it kicked in at a higher temp than the guy wanted to see.
A few questions:
A few questions:
