aux fuel tank sender
this has probably been asked before, but I couldnt find it on the search.
I want to put a sender in my aux fuel tank that I can switch to and have it read on my stock fuel gauge on my 93.
does anyone know of a aftermarket unit, I think they are 90 ohms... is that correct?
thanks in advance
Justin
thanks in advance
Justin
stewart warner senders
the manual shows the gauge full at 5-8 ohms, empty at 60-75 ohms, i ran a stewart warner 439361-f 10"-15" depth sender running 0-90 ohms, and adjusted it to read right on the e mark at empty, to the gauge, at full it reads higher, but i care about using all of the fuel at the lower level, for a deeper tank, 15"to24", use 439363-d, they also have rt and lt hand, but you can flip the rheostat to read opposite anyway, with both my tanks, my range is around 1200 miles, good luck, joe.
silver_2000_tj
10-02-2009 04:31 PM
PRO-NRA
16
04-01-2008 12:13 PM
groran
03-19-2007 07:44 PM
