Autometer fuel gauge bouncing around
Old 06-07-2008 | 09:10 PM
Elohim1's Avatar
My autometer fuel gauge constantly Fluctuates 5-10 psi. It is the electric one and is T'd between the filter and Pump. Using a vulcan regulator and A 2nd gen. piston pump.
Is this normal ?
I would like to hear from someone else using the same gauge.
Old 06-07-2008 | 11:48 PM
b1eric's Avatar
That vulcan regulator is JUNK. I had the same setup, yesterday i pulled it all off and put the stock lp back on.
Old 06-08-2008 | 07:54 AM
Elohim1's Avatar
Who makes a good regulator ?
Were you having the same problem?
Anyone else have problems With the Vulcan Regulator ?
Old 06-08-2008 | 07:55 AM
You need a needle valve or a snubber before the sender to damp the pulsations from the piston pump.
Old 06-08-2008 | 08:04 AM
Elohim1's Avatar
Wanna,
I know you have helped me out a bunch so far, would you mind posting a link to what I need ? I am using the 3/8" line.
Thanks
Chris
Old 06-08-2008 | 08:14 AM
A needle valve can be found in the plumbing section at the local hardware store. It should be set almost completely closed, open it just enough to read the pressure but not so much that the gauge bounces.
You can get a snubber from McMaster-Carr. Their site uses javascript so I can't give you a link. Type "snubber" in the search box, you want a porous disc brass type with a 1 micron rating. The gauge may wiggle a little, but the wild swings will go away.
Old 06-09-2008 | 12:32 AM
b1eric's Avatar
I would'nt waste the money trying to make it work. I tried a few tricks and it never got better. At 65mph my guage moved between 3 and 14 psi while it was bouncing! If I keep this truck I will buy an areomotive, or similar, regulator. This regulator is very poor in my opinion.
maxx250
03-05-2014 03:31 PM
Txwelder
02-19-2010 12:20 AM
Free89W350
04-02-2007 08:44 AM
sleepr tsi
21
03-16-2007 02:16 PM
kelownadiesel
06-01-2006 10:58 AM
Quick Reply: Autometer fuel gauge bouncing around
