Aurora 3000 Turbo and 6x.016 Injectors.........
Old 11-05-2008, 08:31 PM
JQmile's Avatar
I'd pony up the $500 for one of KTA's 14mm heads as well, they're usually worth 100-150hp over stock if everything else can keep up.
Old 11-06-2008, 08:00 AM
pwrtripls1's Avatar
Did you get your tranny yet?
I still havent found the tranny I want yet. Deffinatly not a 727 or non lockup. Maybe a 47rh, maybe an Allison with a stand alone controler. It may be awhile on that.
JQmile, I talked to KTA and from what I've gathered the stock pump with a fuel system that can keep up like an electric unit, big lines, big filter, and a constant 18psi inlet pressure to the VE will make 450whp more reliably than a 14MM H&R pump. Even at 500whp your better off with just a stock pump and good fuel system. If your looking for big power and trying to make 550+whp and the trucks main use is competition than a 14MM H&R kit is the way to go. My goal is to have a reliable long lasting 450 or so whp and have a solid 12 second truck. When all else fails I have lots of extra N2O sitting in the garage. lol
Old 11-06-2008, 06:07 PM
JQmile's Avatar
Sounds like you've done your homework, hopefully the dyno will show some good test results. LOL
Old 02-06-2009, 01:17 PM
The_Head's Avatar
Is the outlet diameter for this turbo 4"?
Old 02-06-2009, 04:01 PM
Yep it does.
http://www.lagunaspeed.com/product/2...arger+Kit.html
roadranger
11-21-2007 11:44 AM
ptgarcia
07-27-2007 02:35 PM
omaharam
29
01-01-2007 04:15 PM
jimjawz
07-08-2004 05:55 PM
jimjawz
06-27-2004 06:16 PM
Quick Reply: Aurora 3000 Turbo and 6x.016 Injectors.........
