ATF how many quarts.
I am servicing my A-727 transmission and I need to know how many quarts of Dexron III will it take to fill the system after it has been successfully flushed, 14-16 quarts?
1991 D-350 A-727
With optional Super Duty Transmission Cooler under the bed.
Thanks Jim
1991 D-350 A-727
Thanks Jim
My transmission has been rebuilt once so there was a new converter installed but still no drain, and I have the axillary cooler under the bed.
I removed the cooler lines and flushed out the trans by pumping new fluid into the trans while watching to old fluid change colors, so far I have put 20 quarts through it and it is almost as clean as the fluid going in.
Probably another couple quarts and I will stop, I think the FSM says 8 quarts but I have been told 14-16 quarts by different trans shops.
I am going to get another 5 gallon pail today to finish it.
So far I have drained out 5 gallons and I am running out of places to put it so I will dump it back into the old pail now since it is now empty.
Jim
Jim
14-16 quarts sounds more like what it would take after a rebuild when the converter is dry. 8 quarts sounds reasonable. You could always flush/add a little and keep an eye on the dipstick.
I know it's a completely different transmission, but when I was working at a diesel shop in Mission Viejo and performing services on the Fords, they would take about 8-10 quarts.
Jim
Jim
xxwildbillxx
08-19-2011 09:25 AM
04ctd
08-04-2008 11:41 PM
jwb600
13
06-17-2008 08:35 PM
Common
04-07-2008 08:30 AM
