ARP studs, Bottoming tap
Where do I find a bottoming tap? I'm going to be doing ARP studs shortly here and need to get a hold of one of a the tap.
MSC, granger, Mcmcaster carr. Any place that sells machinist supplies. If you don't over heat the tap- you can grind a regular tap down a bit and make one.
Ace should have them also..
i get all my machinist supplies for MSC. You have to order some things in bulk though. Like stated above NAPA should be able to get your the size you need too.
1st Generation Admin
Notice the difference in the standard tap vs the bottoming tap.
LovinTheTorque
09-14-2013 12:02 PM
Stovetop535
09-29-2010 10:40 PM
