Anyone regret switching to 3.07 axles?
Old 12-15-2009, 03:54 PM
rbrettctd's Avatar
Originally Posted by mhuppertz
I can't imagine a raggy with 3.08's unless you have a 4,000rpm governor spring in there. Without significant upgrades the 2nd-3rd wide gear spacing would be a black hole. Incidentally, the NV4500 has MUCH more even gear spacing.
I have stock spring still, and its really not that bad into 3rd...just rev it out a little higher in 2nd and then throw it and go. I love this combo. I do wanna step up to a G56 though.
Old 12-15-2009, 04:25 PM
oldcool90's Avatar
Originally Posted by schamran
There are a few people on here with 3.08s, 35's, and 5-speeds I think. I can't remember who they are tho. They said they get good mileage with em. I would love to drive one just to see how hard it is to get em moving. I bet they don't have a problem with wheel slip.
I have 307's,35in tire's and a getrag.I love it no problem getting it to move just stick it in 2nd and let out on the clutch,heck I have even took off in 3rd at an idle though i dont realy recomend it. Pulling a 18' car trailer and my jeep cherokee my truck dont even know it back there,just made a 120 mile trip with my jeep in tow average 70 to 75mph no problems at all,could take off fast from a dead stop than my buddy could in his 2nd gen with a nv4500 and his jeep in tow.
Old 12-15-2009, 04:29 PM
NO_SPRK's Avatar
I regret switching to 3.54s
Old 12-15-2009, 04:41 PM
JustRamIt91's Avatar
and no overdrive
Yeah i know, but this trans is feeling better every day. So its almost worth keeping the 3spd, plus don't the od trans have more problems? Only way i'd change anything is if i found a 6 speed for cheap, or got ahold of an allison.
Old 12-15-2009, 06:45 PM
sshort's Avatar
Ive had both 3.08 & 3.54 gears in my 91 1ton the 3.54 gears were very good for pulling & bottom end take off but took approx 2-3 mpg off. I now have the 3.08 back in & my mileage is between 18&20 I do pull a toy trailer with a unloaded weight of 11,400 & it pulls good with either set of gears just a little slower with the 3.08 but also iam right at 300hp with a 727 3 speed
Old 12-15-2009, 07:46 PM
MoparMarv's Avatar
I'm happy with my 3.07 gears. Cruises nice and quiet all day long at 70-75 mph. I tow a car trailer from time to time with no problems. If your just driving around an empty truck alot they are perfect I think. I start in second gear all the time. However if you plan on towing over 8000lbs alot you may be happier with the 3.54's.
Old 12-15-2009, 08:02 PM
65fury's Avatar
I miss my 3.07s........ wish i hadnt sold them, i know have 4.10s and really have no use for them.... guess ill have to put on some 38's
jason
Old 12-15-2009, 08:31 PM
peobryant's Avatar
Nope, the OD tranny doesn't have anymore problems than a 727. It is basically a 727 with overdrive, so if overdrive goes out, then you have a 727.
Old 12-15-2009, 08:45 PM
PapeCAT's Avatar
Originally Posted by RowJ
That's a big change, IMO..... based on my going from 3.54 to 3.20 (due to 35" tires).
I would never do it w/ an automatic, but with a manual, you may be able to live with it?
If you're at stock power I'd be very reluctant.
RJ
Going to 3.07 with stock tires is nothing like going to 35" balloon tires for higher gearing. You are adding rotational mass, wider tread, lower psi, more contact/surface patch. etc. 3.07 and getrag is an amazing combo for all uses within GVR
Old 12-16-2009, 08:13 AM
RowJ's Avatar
Good points all! I'll bow to those with actual 3.07 experience.
RJ
Old 12-16-2009, 11:58 AM
larry104's Avatar
Thanks to all who responded! Great information. I'm installing the 3.07s this weekend. I'll let you know how it works out.
Old 12-18-2009, 08:28 AM
olskooldodge's Avatar
I was going to put the getrag in my truck with the 3.07's in it but I ended up wondering if I could ever back a trailer at all considering that reverse in the getrag with 3.54's was about a little to high in my opinion anyway. You guys that love the 3.07's and the getrag, what is reverse like?
Old 12-18-2009, 08:59 AM
schamran's Avatar
do you have a 4X4? If you leave the hubs unlocked you can put em in 4 Low, and you can back up a trailer all day long. I do that with my 3.54's. It works great, never have to slip the clutch. -- try doing that in a 2nd or 3rd gen. lol
Old 12-21-2009, 04:24 PM
RSWORDS's Avatar
Why? Been thinking of finding someone with seme to swap my 3.07's with.
Old 12-21-2009, 04:27 PM
NO_SPRK's Avatar
While my auto trans was still in my truck. It was faster and towed better. The 3.54s made my 727 shift very quick and I felt like I wasn't using all my power.
09-22-2019 07:27 PM
95black2615
12-22-2007 10:54 PM
bigbrowndog
09-02-2007 08:16 PM
Kstoner6tb
15
12-26-2006 12:59 PM
SkyHarborCowboy
15
09-09-2005 11:50 PM
Quick Reply: Anyone regret switching to 3.07 axles?
