Any way to tighten steering?
Originally Posted by csramsey640
Ok I spend some hard time, loading/unloading, moving, this, that and the other and under certain conditions I can get the Idler Arm to really move up and down(wore out) by grabbing the RF wheel and moving side to side. Can this cause the concerns of the truck wondering around? Im gonna replace it anyways, just wondered if i was onto something.
Checking for loose part is allway the first thing, align shop should do before alignment is consiedered.
Location: Michigan (see aforementioned rusted-out rockers)
absolutely. you can go from toe-in to toe-out by hitting a bump. the caster andgle should keep you (basically) straight, but the bottom line is that your wheels can change their angle relative to each other and that means wandering.
PourinDiesel
05-07-2006 09:26 AM
Flatty
07-01-2005 02:06 PM
