Another ECM bit the dust
Old 01-11-2015 | 09:15 PM
  #76
Vader93's Avatar
Glad to say only codes showing are 12 (battery) and 45 which is od circuit open or shorted. Of course its open since its unplugged and tapped up under the truck. Which brings me to a new point. On my cruise control not working at all would this be due to the fact that the pcm is not seeing od engaged (grounded out) it would not let me operate cruise control. Should I start a new thread for this or do yall have any input. If I grounded out the overdrive circuit cruise should function right.
Old 01-11-2015 | 09:59 PM
  #77
I'm using the 93 Auto PCM in my crewcab, and the cruise works just fine. Other then the accelerating issue I can't resolve yet. Just hook up the neutral wire as I mentioned earlier and it should work...unless there are other issues in the cruise control system.
And I too am glad you got your charging issue sorted out...Well done!!
Old 01-11-2015 | 10:04 PM
  #78
j_martin's Avatar
I don't think cruise control needs OD to work. There are a lot of places for it to fault out, though.
When you get your FSM, study up on it and have at it. You have the meter you need now.
Old 01-11-2015 | 10:12 PM
  #79
Vader93's Avatar
Thank you. Yes sir. I hooked up the neutral safety switch to the clutch switch like you said. Still no go. Cant wait for my fsm. Hopefully itll show me what im overlooking
ClassA4x4
06-01-2015 08:15 AM
dodgedude361
05-22-2009 01:04 PM
bulldogepd
12-07-2007 11:31 PM
lawnmaniac883
11-15-2007 10:15 PM
bloodhound51
07-10-2007 05:35 AM
Quick Reply: Another ECM bit the dust
