Another blower question(think im close)
New to forum, tons of great info on here!
Just picked up a 93, which apparently sat in a farm field going green for years... tryin to get this baby back in action.
One of the many things im into is the blower fan...after days of forum browsing i feel like im getting close...
Issue is basically no blower power...Checked the fuse at fuse box with test light, which lit up...pulled dash and visual inspection of switch and harness looks fine...all wiring looks good
From someones advice I ran 2 wires from battery + and - straight to blower under the hood and with key turned the blower fired up. Thing is none of the controls (high /low, defrost/ac/off etc) worked, which im guessing its since it just had constant full power.
So now I'm guessing blower must not be getting power to the harness under the hood. Can someone tell me where that harness gets it power from? and there must be a switch along that line which enables the different controls to work ?
Appreciate any input!
nonrev (12-30-2020)
Yeah seems like i have power at the switch.
Appologies if this conjures up old demons...Seems like the answer is out there, read Jim Lanes blower upgrade probly 5 times but im not great with wiring diagrams...
A Few photos...
Seems like i have power from the ignition switch to the back of the blower fuse (black/red wire), but with key turned no power to green wire from backside...
could this have something to do with it? couple broken/orange wire leading to harness to nothing. Is that the same green wire from the fuse panel?
and so where does the power to this plug for the blower come from? (orange/black wire)
Thank you
A Few photos...
Thank you
nothingbutdarts (01-07-2021)
Here is a diagram for the ducksfoot and what each fusible link powers
The following 3 users liked this post by nonrev:
Man, I labeled this and posted it on Facebook so long ago and still have it in my FSM. I'm long overdue to modify it on a computer.
FWIW, this is based upon the wiring schematics from my 1990 FSM. I don't know how similar the later models might be but it seems this has been helpful to many people.
jimbo486 (01-04-2021)
Spoke too soon...
Here's a photo of the switch...Blue is going from back of alternator to switch, which when jumped with a wire from the battery the fan runs. (and the coiled red wire is running to the blower fuse) Therefore thought when truck running that it'd get power...Maybe there's not enough power coming off back of alternator to engage the switch?
Would looove to get this sorted ! Thanks again
Spoke too soon...
What's the relay next to it for? I can't quite tell, but is the blue wire off the regulator piggybacked and feeding that relay?
Yes that blue wire is piggybacking from the regulator, at the yellow crimp wire connector it splits and goes to the relay.
Not exactly sure about the relay, but the red wire that's coiled up in the photo leads through firewall and directly into the blower fuse...So wondering if it's an attempt to get the blower working, or is it just using that blower fuse as a power source when the key is turned.
Cheers
Cheers
Cheers
Cheers
Edwin
So my battery has died a few times while sitting this week..Figured maybe from turning the ignition on and off so many times to try and diagnose stuff....but its a new battery so figured it would be stronger than that.
And then I just took it for it's first proper drive, and while driving watched the battery gauge dropping, and by the time I got home (20 minutes) the battery was down to 9 volts and wouldn't even crank the engine after I shut it down.
So I guess I have a bigger issue than my fan not blowing !
