Another belt?
Another belt?
So my belt started ripping apart today and did a quick search. I'm goin to get a new tensioner set up but until the advanced store gets one in I was goin to put my old spare on... The old belt was a pain to get off and the spare was a hair shorter and would not go on to save my life.Are these belts supposed to be that tight coming off and going on? Am I doing something wrong? What is the part# maybe I have the wrong belt all together.
Most are really tight. Ive had to put a breaker on my rachet to get enough leverage to get mine on before. Sometimes when struggling on the install, its better to take a break, and come back to it. Did that one time and it went right on...lol
Gave up on that spare belt! The neighbor and I tried for two hours and ten different ways and it was not going on there. Autozone had one in stock that was an inch longer so I figured I'd give it a shot. Put the new tensioner and belt on and fired her up... She squealed like a stuck pig, figured the belt was just a lil too long and then the neighbor noticed the belt wasn't moving at all. Shut it down pulled the belt off and realized the alternator blade was stuck on the new tensioner. Do I grind the new tensioner down to fit or try to get the right one from the local "the computer only shows that part for that vehicle" store. Thanks in advance guys!
Pulleys look the same? Locating pins in the same place? etc ...
Are you absolutely positive of the routing of your belts ??
I have never had the least problem removing/replacing belts on the many Cummins around here; we just use a normal ratchet in the square hole and it is an easy one-man job.
It reads to me like maybe you are routing the belt wrong if you are having that much trouble getting it on.
Unless it's untaxed, then it's red.
Slide the belt on to the alternator last. With a nice foot long breaker bar its defiantly a one man job.
I gave up on local parts stores years ago. Everything for my truck comes from he UPS man. Even after paying or shipping I save lots of money. Get on WWW.rockauto.com or genos garage or any other site you see mentioned around here.
I have found that it works best for me to do the research and then go to the local parts-store already equipped with the correct part-number that I need and make no mention of what it fits.
I know that they don't hire Einsteins to work behind counters; but, to compare parts-guys today to the ones of 30-years ago is not fair either.
Back then, there were maybe ten different makes of vehicle and vehicles hadn't even existed for very many years, so there wasn't much room for mistakes.
Today, there are hundreds and hundreds of makes/models, with dozens of options available within each model, and thirty more years of changes to add to the mix.
It is no wonder we now have to put up with all this "I can have it tomorrow" business; with so many millions of tiny pieces to choose from, it's a miracle that they can even get stuff that quick.
The pulleys look identical, the pin is in the same place, it just seems to be thicker all the way around. They're both dayco tensioners but the #s on the back differ between the two(wasn't sure how long the old one was on thought maybe it was a discontiued part#).
I do this also, amazing if they can get the part number I asked for it is right. It is too bad, but they do not hire good parts people here. I have gone in asked for a part and get " we can't get that" go home look it up on their web site and what do you know, they can get it.
DodgeDiesel61
01-26-2019 07:45 PM
DodgeDiesel61
0
07-28-2010 11:14 AM
Jezzhuntin
08-25-2006 02:51 PM
