Amazed with the difference in power
Old 01-12-2007, 08:11 PM
rlyons's Avatar
Originally Posted by efbeason
Has anyone tried the lift pumps off ebay? I called my local Dodge dealer a couple days ago and the lift pump costs $144.00 from them. From ebay I can purchase a lift pump for $49.00. What is the difference? Are Mopar parts that much higher than Delphi or any other brand? Thanks!
I've been running one for two years now with no problems at all.
Old 01-12-2007, 08:36 PM
tomd's Avatar
Regarding brands from ebay
Do they come with a pump, spacer, gaskets, and an advanced line?
If so, than you got a great deal.
I might buy one just for a spare.
Old 01-12-2007, 09:17 PM
Let me get this all absorbed.
Wanna, you have an electric Walbro fuel pump that has it's pressure end tee-ed into the fuel system between the mechanical pump and the injection pump, such that you can run on the mechanical, and flip on the electric at will??
Do you have a Walbro link??
Why the Walbro, and not the FASS??
Thanks.
Yep, that's the way it's set up. For more info read this thread:https://www.dieseltruckresource.com/...d.php?t=120066
I got most of the pieces from GDP http://www.glacierdieselpower.com/ , the rest came from McMaster-Carr.
The Walbro is a high pressure, high volume pump. It is putting all the fuel it can pump right to the injection pump, the excess is bled off via a bypass regulator. Fuel pressure ranges from 15 to 18 psi.
A FASS is an internally regulated setup, so the filter acts as a false load. You have your 15 psi up to the filter, after that the pressure depends on the restriction that the filter imposes - just like the factory setup. I would expect to be able to drag a FASS down the same way I can drag the piston pump down. That's not intended as a slam on the FASS, it's more of a slam on our puny filters. I see 7 psi drop through the extended filter with the Walbro - although that's with around 65 gph flowing through the filter.
Old 01-12-2007, 09:38 PM
Ilikebikes's Avatar
I bought mine from ebay maybe 4 months ago. No problems yet. I got one of the ones that were going for like $49 that were surplus. Didn't come with lines or spacers or gaskets, had to go to the San Leandro Cummins for that stuff.
Old 01-13-2007, 08:26 AM
banzaitoyota's Avatar
I have mine in. Runs great Still need to do the 3200 spring and advance the timing for the PODS
lovinCTD59
12-23-2008 11:10 AM
Roperteacher
05-19-2008 10:11 AM
wana12v
10-04-2005 05:34 PM
csramsey640
09-27-2005 11:28 AM
stevesmitty
03-21-2005 03:38 PM
Quick Reply: Amazed with the difference in power
