Air to Water Cooler
Thanks for sharing, Flash ha haha Yea, I'm Mr. diesel dummy here, but I think it's called an aftercooler? to increase the charge density of the incoming air forced by the turbo? I can't imagine it would have much effect on EGT's....? Intercooler/Aftercooler I get confused but maybe it would be better to increase density before induction into turbo? But then again that makes the turbo work harder, hmmmm!
Harder, but more efficient.........Kinda like going from 7000 feet(where i live ) to a much low elevation, say 2000 feet.
the turbo would have to work harder, to pull the much densor or compact air in but the boost would be the same!
Same boost levels, but cooler air equales more usable are per pound of boost!
Thanks Wanna, I was thinking I would need the injection lines too. Would the cooler even fit under the hood?
I thought I had seen a pic of one b4 on ebay or on here. I'll check into a particular scrap yard for boats that I know of. I don't know if they'll have anything that big considering I'm in the middle of Kansas
there were some pics at tdr of this setup user therabbittree used on his '89 4x4. the water was from an icebox in the bed!
I had a thought Since a marine scrapyard is hard to come by out here, I could have better luck finding one from a tractor. I know a lot of combines use the 8.3 cummins and a some have water coolers. Any chance that the 8.3 manifold plate is the same size as the 5.9? Of course now I still need the injector lines.... I'll look for some 5.9 apps too in smaller tractors cuz there's obviously tons of those. Not sure if any have the coolers though. Thoughts? Knowledge? Thanks
Dan
Dan
Just bumpin the thread.... Anybody know if the 8.3 cummins water cooler will fit on a 5.9 manifold? And if the injector lines are roughly the same size? Any more input is greatly appreciated! Excellent replies so far, good ideas!
Darek
11-22-2009 01:28 PM
MikeThomas
08-10-2007 12:56 AM
