air horn
air horn
yesterday I was stuck in heavy traffic south of New Haven with several occasions to use my horn (* cutting in front of me, dummies texting while driving, etc.)
the stock horn just doesn't cut it vs. today's stereo systems
so of course I'm now thinking AIR HORN to rattle some windows
has anybody used a kit from Jason at Air Horns of Texas?
This kit is $320, would mount the compressor and tank along the front center wall of my tool box to keep it dry
I use the same compressor and a similar tank on my setup, though my horns are different. The compressor keeps up just fine for the horns, but for use as an OBA system, it's quite slow. Filling tires, for example, takes a while, and it's clear the compressor has a hard time keeping up.
OBA = on-board air?
I would imagine that the tank could top off tires, which is all I would use the Y fitting for
I never operate my truck on sand or soft material, so no need to air the tires down.
I am a stickler about cold tire pressure tho'
I already had on board compressors and a tank. I added a 4 trumpet air horn from Flea-bay. I will find out who and post when I get home. It is VERY LOUD!
O.K., What is an "*" ????????
now, back to airhorns: I plan to mount that long chrome trumpet underneath my big front bumper, can't decide which way to point it (or GET TWO and point them in opposite directions )
Last edited by BC847; 06-27-2011 at 04:05 PM. Reason: Language, shortcuts, & implied language
As far as the horn goes, one thing to consider is the pitch of the horn. My guess is that big horn is going to be low and deep, which sounds cool and all, but perhaps not as startling as a higher-pitched horn. The ones in my rig sound a fairly high pitch and are dissonant in tone - they even make me jump a bit in the cab when I hit the switch for them!
Here's a video comparing the electric horn on my rig to my airhorns:
I'm told that the longer the trumpet, the lower the sound
I'm looking for something that will let someone know that I don't approve of their behavior
I had a young punk in a VW sedan very nearly clip my front bumper as he passed me on the right, and then swerve left less than 6" from my truck (at 80 mph)
as a matter of physics, I believe that the beltline of his car would have massacred by my bumper had he made contact, and he probably would have cartwheeled down the road after that
I don't want you guys to think that I drive around looking for trouble. I'm usually found in the right lane at a speed a little lower than the limit. I only get into the center lane to get around people that are traveling 10-15 mph beneath the limit.
Sometimes I think that hotshots count on guys like us to keep a steady, predictable pace so they can use as moving pylons
those are the people I want to "notify" (or record on video, look at the truck cam thread I started)
we are driving 3-ton rigs that can do a lot of damage if they come into contact with something weighing a lot less. but talk to any 18-wheeler on that topic.
for some reason it's up to US to take all of the precautions so thoughtless drivers can act as if we're not there
I do not go around scaring pedestrians
I wanted something that could be heard on the highway over some idiots stereo. Mission accomplished!
I have a single 30" Grover air horn mounted under my floorboard, it is operated using a lanyard control valve mounted above the drivers wind vent, air is supplied from a Viar 380-C electric air compressor and my dual air tanks are kept at 160 PSI and they are LOUD.
I have a set of horns that I am going to mount under the rear bumper to politely alert the pedestrians that cannot see me when I am backing up.
My compressors is plumbed using 1/2" Nyflex air brake hose to the tanks and the horn is supplied using 3/8 Nyflex air brake hose.
If you want an air horn that will get someones attention then get a Grover "Stuttertone" they are used on Fire Trucks.
The longer the trumpet the lower the tone that is emitted, the short air blast horns are high pitched like on European cars.
Jim
Jim
Check out www.hornblasters.com They seem to have some pretty nice stuff, plus video with sound comparisons.
but this horn serves as an auxiliary to the one in the middle of your wheel, correct?
which leads to the question: in what circumstances do you use it?
